mounting things on the wall
PumaJanVan
I would like to mount a little wire rack over my stove for spices. what is the best way to do this and not put a hole through the side of the camper (outside). Is there something that will stick to the walls and not fall down while you are traveling? So we won't have to put a hole in the wall.
You guys and gals have always came up with a solution to all of my questions.. Thank you
gigi
10 REPLIES 10
LarryJM
gigi
I'm a big fan of the moly anchors for heavier items and I also don't like putting random holes everywhere, but a few isn't going to effect the value of your trailer in the end IMO and you'll probably leave whatever you mount there permanently anyway.
I also like the 3M Command hangers, but be aware there has been at least one report of them actually pulling the vinyl wall covering off the wall so that is something to keep in mind.
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
NYCgrrl
Or heavy weight/heavy duty Velcro. Thing of beauty and not much additional weight added. You can use a heat resistant glue to attach the back piece or staples. I hang a triple lined valance in my L/R from the stuff and as long as you seat it properly it's not coming down.
BTPO1
camperpaul wrote:
Gigi,
I would use 3-M "Command strip" hangers - many different styles available.
Be sure to clean the wall with alcohol before you attach the strips, otherwise the greasy film will prevent them from sticking.
X2, that is what we are using and have none come off the wall yet. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
hotbyte
Never tried a stick on type product but have mounted several things using short molly bolts (metal and plastic style) without poking hole in outer wall (knock on wood). I use a stop collar on drill but and go VERY VERY slow. Be sure to get the molly bolts 1/8" thick walls...1/8" thick...is that an oxymoron ๐Ÿ™‚ ๐Ÿ™‚ ๐Ÿ™‚
2018 Minnie Winnie 24M
Bucky_Badger
I'm thinking the 3M products would fail with the heat from the stove
2010 F150 5.4, 3.55, 4x4, Equli-z-er Hitch
2007 Forest River Salem 27RB LE
and
2009 Nomad 3980
1492
Moderator
Moderator
Moved from Forum Technical Support
camperpaul
Gigi,
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
I hung a decent size wall clock using 3-M tape hangers.... And my DW will tell you that I'm not the best driver :B and yet that thing stays hanging there trip after trip!!
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Not_a_Clue
We use all kinds of different 3M tape products, they have everything from hooks to double sided tape. Check them out.
Linda B.
Our Blog
2009 29' Fleetwood, Fiesta V10 - The Little Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
FMCA# F412985
Traveling with Robin(friend)& Buddee(cavalier)
Tom_M1
Mount the rack to a piece of wood then attach it to the wall with construction adhesive. I use Loctite PL-Premium. It's available in squeeze-tube or caulking tube.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
