Need help with tow setup driving from NJ to TX
aedubber
So i am moving from NJ to TX in a few weeks and i really dont want to put any mileage on my Jeep . I have a 2012 Jeep Grand Cherokee 4x4 Automatic , and i was thinking about using this to move it on since i dont want to drive it.
http://www.uhaul.com/Reservations/EquipmentDetail.aspx?model=AT
I am moving a bed, desk, 2 dressers, and clothing. So i am not packing up a lot of things to move but i will be renting a 14 or 16ft moving truck to haul my things. I was wondering if this combination will work ? The towing numbers look good on the moving trucks , im just not sure if the auto transport dolly will be okay with my Jeeps weight?
Would you guys advise i tow a different way or will i be safe? I am not in a rush, so i will drive carefully. Any help will be appreciated. Thank you !
I didnt know where to ask this but i figured this would be a good place.
6 REPLIES 6
tropical36
We would normally call this a car trailer, not a dolly and the way I would go, if it was me.
rjstractor
The trailer listed has a load capacity of just over 5200 lbs., so no worries on weight for hauling your Jeep. Uhaul probably would not rent you a truck and trailer combo that was over capacity so you should be fine there.
2017 VW Golf Alltrack
2000 Ford F250 7.3
aedubber
My Jeeps weight is 4660 . I plan on keeping it on E gas wise to save weight there. Yes , it will be a 1 time tow with the dolly i posted.
dons2346
If it is going to be a one time tow, then rent a trailer like the one you posted and be done with it.
imgoin4it
Do not believe you can use a car dolly to tow a jeep. If you can put the transfer case in neutral you can probably tow it 4 wheels down, or you can trailer it. But don't believe you can use a dollyput.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
bamcote
Clicky
Don't know what your Jeep Grand Cherokee weighs but I hauled a Chevy Trailblazer 4x4 on one behind a 26ft box truck 1200 miles with no problems.
DH, DW, Tildie, Bella and
Molly the Maine Coon
and Greta the shorkie pup
2008 Fleetwood Bounder 36Z
2007 Saturn Vue AWD with Ready Brake Brute
