โAug-06-2016 05:22 AM
โAug-08-2016 06:39 AM
wanderingbob wrote:
...I can get 33 feet in a tire of nitrogen at sea level...
โAug-08-2016 05:25 AM
โAug-08-2016 04:02 AM
After reading these posts. It appears to me some of you guys need to get a hobby.I guess I don't think a lot about the air in my tires, if they are not flat, I'm in good shape. But I did get a chuckle from the posts.
โAug-07-2016 09:13 AM
โAug-06-2016 10:43 PM
Dtank wrote:Strabo wrote:
I change the air in my tires, and have them rotated so the letters on the sidewall standup when i come to a stop. ๐
I tried that but the darn tire lettering wouldn't line up when I got
it home.
Also did the helium thing, but found it had too much "float", and I
was losing traction on steep hills with no load in the pickup bed.
BTW - the folks carrying small nitrogen tanks -vs- a compressor, should look into C02.
Go to Power Tank- then make your own.
Off roaders and RVers been using C02 for a looooong time!
Fill at: Paint ball stores, home brew stores, welding supply, etc.
Expansion ratio of C02 liquid to a gas is 450 to one.
โAug-06-2016 10:37 PM
Turtle n Peeps wrote:
No, you're not correct.
You don't need a vacuum pump to get 99% N into a tire.
Here's how you do it. Get as much air out of the tire as you can without blowing the bead off. Put the valve stem back in and fill with N.
Bleed all of the air/N out of the tire.
Fill with N again.
Fill with N again.
Each time you do this you get a higher concentration of N into the tire. After about 3 or 4 times you have "pretty much" 100% N in the tire.
โAug-06-2016 07:40 PM
โAug-06-2016 05:48 PM
โAug-06-2016 05:02 PM
โAug-06-2016 04:55 PM
dave54 wrote:
I use helium. My truck just seems to float down the highway.
โAug-06-2016 03:43 PM
โAug-06-2016 03:24 PM
โAug-06-2016 02:57 PM
wanderingbob wrote:I had to look hard to find that.. and really didn't. I was simply stating its PSI measurement. A deflated tire would have 14.3 psi.
Goggle (sic) sez one atmosphere is a column of water 33 feet high , as a former SCUBA instructor 33 feet equals one atmosphere
โAug-06-2016 02:44 PM
