โJul-11-2014 03:03 PM
โSep-24-2014 08:54 AM
โSep-24-2014 08:23 AM
โJul-18-2014 10:18 PM
RCMAN46 wrote:
I have three vehicles that I use to tow my utility trailer.
I use one Prodigy P3 for the three.
Each vehicle has its own wiring and mounting bracket. Very easy to move the Prodigy that way.
โJul-15-2014 01:33 PM
โJul-15-2014 09:57 AM
โJul-15-2014 09:54 AM
sonuvabug wrote:carringb wrote:
Also, the Fords do not come with the trailer battery charge relay installed. It goes under the hood. It is supposed to be in a baggy with the owners manual, if you still have all that stuff.
Dang ... I knew I'd be found out. I do have the original baggy with a few odds and ends in it. However, I AM NOT an electrickity guy at all. This sounds like I need to run a separate line to the trailer for the breakaway unit battery source or are you talking about something else?
โJul-15-2014 06:38 AM
โJul-12-2014 07:38 PM
โJul-12-2014 07:36 PM
โJul-12-2014 06:12 PM
sonuvabug wrote:ScottG wrote:
Yes, you can get ready made harnesses for both vehicles or make your own. Either way it will have the same plug on the P2 end. You'll want to get another mounting bracket though, otherwise you'll have to unscrew the bracket and move it between vehicles.
Never thought about the extra bracket ... thanks. Are the ready made harnesses available from Teckonsha?
โJul-12-2014 08:36 AM
โJul-11-2014 03:36 PM
