โApr-26-2017 06:47 PM
โJun-06-2017 01:43 AM
irishtom29 wrote:
In 35 years as a heavy rigger I learned that working right up to a rated limit is good. Close and under is good. Over is bad. I needed my WD hitch to get my truck within limits. I used it then weighed it. It was good. The tongue weight (I had a scale) was just under the receiver limit. All was good.
โJun-05-2017 06:15 PM
โMay-30-2017 07:19 PM
โMay-11-2017 06:37 AM
โMay-11-2017 05:50 AM
Bobbo wrote:
I have been studying Ron Gratz's example of the 2000 pound lift WDH, in the sticky on this forum, and have a question.
If the tow vehicle has, say, an 1800 pound payload rating, and loaded for camping WITHOUT a WDH you are carrying 1600 pounds of payload, including tongue weight. That means you are 200 pounds below your payload rating.
Now, you add Ron's WDH that shifts 300 pounds to the TT axles. Does that mean you are now 500 pounds below your payload rating?
Thanks,
Bobbo
โMay-10-2017 01:13 PM
โMay-10-2017 11:06 AM
โMay-03-2017 10:33 PM
Grit dog wrote:
Cmon blt2ski, you can't possibly believe all of what you just wrote....
300lbs off the front and a 1 ton truck gets squirrelly??? Lol
Based on what?
Starting with a heavy diesel and then get in a gasser and the front end is light because the engine weighs 500lbs less?
Better get that wdh oiled up for the pop up behind the ole 1 ton! Goin campin!
Bobbo, it's a 3 ton trailer going behind a truck rated for and capable of towing considerably more Than that. Don't lose any sleep unless it's from the excitement of having a new airstream and brand new pickemup truck in the driveway soon!
โMay-03-2017 06:39 PM
โMay-03-2017 08:01 AM
โMay-02-2017 06:21 AM
โMay-01-2017 09:20 PM
drsteve wrote:
Too much tongue weight can exceed the rating of the hitch receiver when not using WD. The numbers are on the receiver. On my truck, it's 500 lb tongue without WD, 1000 lb with. Max trailer is 5000 without, 10,000 with.
Again, these are receiver ratings, not the truck itself.
โApr-30-2017 12:54 PM
โApr-30-2017 08:49 AM
