โJun-28-2013 02:59 PM
โJul-06-2013 05:31 PM
โJul-05-2013 12:16 PM
โJul-05-2013 12:02 AM
โJul-04-2013 03:26 PM
Ron Gratz wrote:
Art, I found online sources which indicate your trailer has an empty weight of 5300# and a GVWR of 7100#.
If these values are in the right ballpark, the TT's loaded weight might be in the range of 6000-7000# depending on how much stuff your carry.
The corresponding tongue weight might be 700-900#.
myredracer wrote:Gil, just so we don't burden Art with conflicting information -- perhaps the 7000# value you found was for GVWR rather than dry weight?
I have to wonder if your TV may undersized for your trailer? The info. I found says that your trailer has a dry weight of about 7,000 lbs, but I could be wrong. Actual loaded weight including any factory options, *could* be in the range of 8,000 - 8,500 lbs. If the tongue weight is in the usual/recommended range of 10-15% of the trailer weight, you could be looking at up to 1200 lbs or more of actual tongue weight.---
โJul-04-2013 01:18 PM
โJul-03-2013 01:10 PM
โJul-02-2013 05:26 AM
โJul-01-2013 07:44 AM
โJun-30-2013 09:15 PM
agillings wrote:IMO, it's not necessary to use the air bags to make the truck level.
Ron one additional question. I also have a bags in the rear. I need to know how these shoulds fit into the over all setup. Do I inflate these to make the truck level with the trailer attached? Or should I set up the WDH and then use the air bags to level it all out?
โJun-30-2013 09:06 PM
agillings wrote:Art, I found online sources which indicate your trailer has an empty weight of 5300# and a GVWR of 7100#.
Thanks Ron
Before I do you reccomendations, do I have the right size spring bars?
The Tag on the bar reads:
550 weight Dist
10,000 Max Gross Trailer weight
550 Max Hitch Weight
โJun-30-2013 06:03 PM
โJun-30-2013 05:49 PM
โJun-30-2013 10:14 AM
agillings wrote:That depends on how much load transfer you're getting with the current setting.
Thanks. Ok so maybe all I have to do is tilt the head of the WDH. Would it need to be Tilted toward the TV or Trailer?
โJun-30-2013 09:16 AM
