โMay-18-2015 10:01 AM
โMay-18-2015 04:15 PM
โMay-18-2015 04:10 PM
hawkeye-08 wrote:Old-Biscuit wrote:
Try the 'swoop' method
Approach site on drivers side
Drive close to same side of road as site is on
When you get to site entrance turn truck away from site when front tires of trailer just reach the edge of site entrance
When truck is at 45* turn back opposite way
When front of truck is parallel with road stop
Truck should be straight and trailer at a 45* angle with backend of trailer just past site entrance
Turn truck wheels to right......start backing up and then chase backend of trailer by straightening out/turning truck wheels to left
Use trailer tires as guide and follow imaginary line going back into site where you want trailer tires to be.
Slow, slow..........did I mention go slow and make adjustments watching trailer tires
yep, x2
โMay-18-2015 02:33 PM
โMay-18-2015 01:25 PM
โMay-18-2015 01:17 PM
โMay-18-2015 12:48 PM
โMay-18-2015 12:41 PM
AH64ID wrote:
I would get the 5er more to the left of the drawing and make an input so your turning by 2, which means you will probably have to start the input at 3-3.5 depending on the width of the road.
โMay-18-2015 11:57 AM
โMay-18-2015 11:46 AM
AH64ID wrote:
Like fla said just take your time. You will find aspect of the longer WB easier and aspects of it more challenging.
Practice practice practice.
Go to walmart when they are slow, with the trailer, and get 4 orange cones. Make yourself a parking spot and back in and out of it. Play with the TV/TT to see how it reacts. Figure out how far you have to pull past the site to back it in easily and in one motion. All too often I see people stop to close to their spot and get in a bid, further is always easier as you can back up to the proper pivot point.
โMay-18-2015 11:43 AM
Porsche or Country Coach!
โMay-18-2015 11:29 AM
โMay-18-2015 10:21 AM
โMay-18-2015 10:12 AM
