Tomboy2 wrote:
Have spent the last few days in Texas in 90 plus temps. The roof air runs almost constantly in an attempt to keep the coach cool. Should I be concerned abut the units overheating?
NO, just yourself oveheating.
IF the Roof Air overheats.. it will stop.. Here is why.
First the motors are thermally protected, if they get too hot the thermal breaker opens and shuts them down.
Second (And you may wish to check this in the AM) if the condenser coil gets gunked up (Which is normal by the way, it happens) then air can not pass through it properly.. I have two A/C's on this 38' class A, one of them suddenly strated popping it's circuit breakers.
Had an Idea, went up on the roof with screwdrivers and compressed air and popped the covers.. Applied the compressed air to the coils in a manner designed to de-gunk them and.. It works great now.
(Other A/C 2 days ago went BOOM Vibrate,Vibrate,Vibrate (Shut off by me) went top side and found I had been China-Bombed.. The condenser fan blew up... If anyone has an Advent Air (Seems they are made in China and imported) The condenser fan is identical (With one minor difference) to a Coleman part.. The difference, better construction on the coleman part.
