Rubber Roof Cleaner and Protectant
pmlevine
After it stops raining here in the NE, I will be cleaning the rubber roof on my TT. I've done some research and believe the best option is to use a medium bristle brush and clean with a solution of Murphy's Oil Soap. Then when dry, apply Airspace 303 Protectant.
As always, I will appreciate what other more experienced RV's do to clean and protect their rubber roof.
21 REPLIES 21
LarryJM
TxGearhead wrote:
Wet and Forget
Same here, IMO scrubbing and rubbing only shortens it's eventual life.
The only time I would do anything is if and when grass and weeds started growing from the dirt build up:W
Larry
2001 standard box 7.3L E-350 PSD Van with 4.10 rear and 2007 Holiday Rambler Aluma-Lite 8306S Been RV'ing since 1974.
RAINKAP INSTALL////ETERNABOND INSTALL
pmlevine
Here is a photo of the rubber roof on my TT, discolored from weathering. It at least warrants cleaning - just hosing down is not an option. I'm still not sure if/what UV product to use afterwards.
2012Coleman
I was given CamCo roof cleaner available at Walmart. It sat on the shelf for a long time, but then I went to clean the roof and didn't have my usual Spic & Span so I used it. Was not enthused while cleaning, but the rinse water was brownish. But when it dried, boy what a difference - very white and bright. Here is a picture I used for selling it taken after cleaning it and laying down caulk. I use a soft brush on a threaded pole.
2018 RAM 3500 Big Horn CTD
gbopp
I use Aerospace 303 Protectant on everything except the roof.
And, with all the rain, I don't think it will be necessary to clean the roof IF it ever stops raining. My roof looks pretty good.
lenr
Talked to Dicor (who makes most of the rubber roofs) at a Good Sam rally a few years ago. They recommended using their cleaner and protectant saying that the more expensive treatments are not needed.
Lwiddis
Thatโ€™s not what Winnebago recommends. โ€œThis rubber roof material does not require coatings to protect the surface from ultraviolet light or ozone.โ€œ
I didnโ€™t use STP back in the day either.
TxGearhead
Wet and Forget
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
