โJan-12-2015 05:54 AM
โJan-13-2015 06:36 AM
โJan-12-2015 09:41 PM
โJan-12-2015 06:01 PM
โJan-12-2015 03:43 PM
โJan-12-2015 07:35 AM
drsolo wrote:rjxj wrote:
Sorry cant help with a repair place but may I please just offer my opinion on this matter. I would seriouslyconsider a new furnace at that age the heat exchanger is probably rusted also. If the original supply piping is black pipe it could well be rusted too. I would consider replacing it with new hose purchased from a propane supplier. It's probably a gravity type heater, I have looked for them myself with no luck you will probably have to replace it with a fan type model which will then use battery power.
There is no "battery power" in this little old Shasta, but the rusty heat exchanger should be considered and checked. Replacing the furnace would most likely be cost prohibitive. I loaned my friend a little plug in quartz heater.
โJan-12-2015 06:54 AM
โJan-12-2015 06:38 AM
