Sagging rear springs when towing.
elliotthere
Trailer max GVW 10,000lbs Hensley WDH.I want to install Hellwig helper springs 1000 lb rating, Is this the right rating.
Thanks for any advice Dave
Dave & Joanne
2004 Ford Excursion, Eddie Bauer 6.0L
137 in wheel base,3.73 axle,
Prodigy brake control,
Hensley Arrow hitch,
2004 Starcraft Homestead 29SKS.
7 REPLIES 7
Adam_H
I had to add air bags to my EX to overcome the soccer mom springs Ford put in, and I have been very happy with the results. Thought about a spring swap (X code I think) but didn't want any lift/height added to it. Seems to barely fit in a lot of the parking garages in the area with only an inch or 2 to spare.
Adam
2007 Fleetwood Avalon HW PUP
2001 Excursion 6.8L V10 3.73
2005 F150 5.4L
Gone but not Forgotten: 1971 Trailstar PUP, 2002 Fleetwood Wilderness Northwest Edition, 2002 Keystone Bobcat 280-EB
APT
My understanding is the rear springs are fairly soft on the Excursion, and these exact ones are now 13 years old. I'd talk to a suspension shop about just replacing them with some that have a little higher spring rate.
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
goducks10
OP's setup per profile
Ford 2004 Excursion Eddie Bauer 6.0L
3.73 rear axle
137 in wheel base
Hensley Arrow hitch
Prodigy trailer brake
Starcraft/Homestead 29SKS
JIMNLIN
Give Helwig a 1-800. They can give you what actually works. We can only guess what works.
Hannibal
The rear of our F250 settles 1.5" with the hitch properly adjusted. This is normal. How much sag are you seeing?
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4
2010 F250 XLT CC SB 5.4L 5spdTS 3.73
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'
1492
Moderator
Moderator
camp-n-family
What do you mean by sagging exactly? 1 inch? 5 inches? What is your tongue weight? Is the hitch adjusted correctly?
Some sag is normal. Even with the hitch adjusted you will still have a couple of inches of sag.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
