side of camper pushing out
bernie320
The left front side of my Springdale looks like its getting air under itgoing down the road it pushes out a bit. I am a new camper owner how can this be fixed? thank you for any advice
6 REPLIES 6
hokeypokey
As we followed a 5th wheel, we noticed some objects flying off but didn't know what was happening until a large section of his siding gave loose at the front seam and flapped in the wind. Lots of traffic so it was difficult for him to get pulled over. Note to self: check your unit over
Dakota98
Close the window on the other side of the trailer.
I'm an expert in only one field....I believe it's somewhere in Kansas.
2000 / 22' SKYLINE NOMAD LITE
1998 DODGE DAKOTA / 5.2L= 8mpg.
2006 POLARIS ATV
1500/1200 Watt Champion generator
Yada Wireless Back Up Camera
1998 Dyna Wide Glide
USMC 68-74
bernie320
Its the aluminium siding, not the frame.
therink
Are you referring to the aluminum skirting or side (structural) wall of the camper? Big difference.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
Shadow_Catcher
From what I can see the side is Filon, there are a couple of possibilities. The Filon has become dis-bonded from it backing the backing has separated from the frame, or water has gotten in and caused dis-bonded from its backing.
1492
Moderator
Moderator
Moved from Forum Technical Support
