Somebody educate me on "Nitrogen" in the tires ?
NanciL
We just bought a new Travel trailer and I never noticed at the dealers, but saw a sticker on the side today that said there is nitrogen in the tires.
Someone please explain what this is for.
Jack L
Jack & Nanci
40 REPLIES 40
mike-s
Air is 4/5 nitrogen. Pure nitrogen leaks through the rubber a small bit slower than the other 1/5 gases in air. So, if you don't check your tire pressures as often as you should, it's very slightly better. No oxygen, so the inside of the rubber tire doesn't deteriorate as fast - but it makes no difference since the outside, which is exposed to more than just oxygen, is what fails first.
There's nothing bad with filling tires with nitrogen, but it's definitely not worth any additional expense or effort. It's just a marketing gimmick.
wnjj
Harvey51 wrote:
However, the Costco I go to has a large compressor in the back of the tire shop - I wonder what it is for.
Probably for the air impact wrenches.
DrewE
It's mostly a way of separating you from your hard earned cash, and then shifting some of the latter to the merchant's bank account.
There are some advantages to using nitrogen vs. ordinary air in tires, but they're entirely immaterial for ordinary uses. If you're a formula 1 racer or a jet pilot, then you may actually start seeing some real benefits.
I suspect nitrogen of the purity that would be used for tires is more frequently generated by removing the oxygen from the air with an oxygen concentrator than by liquifying the nitrogen. I may be entirely wrong, though. (It's doubtful in any case that they would liquify the oxygen in extracting the nitrogen, since that requires a much much lower temperature.)
fj12ryder
It's a useful tool for transferring that green stuff in your billfold into the hands of the service station putting nitrogen in your tires. Other than that, just hype.
Howard and Peggy
"Don't Panic"
kennethwooster
I've had tires come out with Nitrogen, but in my small community there is no Nitrogen. Thus mine all end up with regular air just like I've used all my life.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
jplante4
Mine had helium and the GVW was 1000 pounds more than a stock Sahara.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
CavemanCharlie
Gimmick.
dodge_guy
We put it in all the tires at our shop. its a sales gimmick! unless your racing there is no use for it in everyday cars!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Harvey51
It means the oxygen has been removed from the air to reduce chemical reactions with the inside of the tire. Costco famously uses nothing but nitrogen. Nitrogen is produced by cooling air to liquify it, forming separate layers of pure nitrogen and oxygen. Not something that can be done in a store so nitrogen must be delivered in high pressure tanks. However, the Costco I go to has a large compressor in the back of the tire shop - I wonder what it is for.
Some say the main advantage is that the nitrogen gas has a very low moisture content.
Much more here: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=191&affiliate=IT2&s_kwcid=AL!3756!3!67192535288!b!!g!!_cat:tires&ef_id=ViZl0wAABG0LmA8c:20161101003739:s
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
safeman
I keep a precise mixture of 78 percent nitrogen in all my tires:B
12th_Man_Fan
nitrogen is supposed to be better for the tires and less sensitive to temp changes but unless you have a supply of nitrogen it is a pain. Mine came with nitrogen but I have added regular air since I have had it.
Doug
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
