Somebody educate me on "Nitrogen" in the tires ?
NanciL
We just bought a new Travel trailer and I never noticed at the dealers, but saw a sticker on the side today that said there is nitrogen in the tires.
Someone please explain what this is for.
Jack L
Jack & Nanci
40 REPLIES 40
Turtle_n_Peeps
mike-s wrote:
Turtle n Peeps wrote:
rbtglove wrote:
Nitrogen is used in A/C tires and some race cars primarily because it is not flammable like the oxygen in air.
Oxygen is flammable?
In a literal, pedantic sense, no. But the GP's statement should be taken to mean that nitrogen doesn't support combustion like oxygen does.
If my tires or race car is on fire, the last thing I'm going to worry about is the 20% of O2 in the tires because there is a whole bunch of it around the car to support combustion
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
dave54
Put helium in your tires. Your rig will seem to float down the highway.
So many campsites, so little time...
buta4
safeman wrote:
I keep a precise mixture of 78 percent nitrogen in all my tires:B
LOL! Me too.
Ray
fj12ryder
rbtglove wrote:
Nitrogen is used in A/C tires and some race cars primarily because it is not flammable like the oxygen in air. It also has a slight advantage in stability/leakage expansion. It is pretty much a waste of money to use in RVs.
BTW, oxygen isn't flammable.
Howard and Peggy
"Don't Panic"
mike-s
Turtle_n_Peeps
Oxygen is flammable? :h
outside the fire"
d3500ram
LOL... I was also going to add that the N works better in high altitude states like the one in which we live... that also provides for less density resulting in better mileage
:B
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Clay_L
d3500ram wrote:
Nitrogen is slightly less weight than normal compressed air therefore the slightly less weight on the tires provides for less rolling resistance resulting in better fuel millage.
๐Ÿ˜‰
Glad I saw the smiley way down on the left side before I sent a nastygram. ๐Ÿ™‚
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
rbtglove
Bob/Beavercreek OH
2011 Silverado 1500 LTZ/Trail Lite 8230
d3500ram
๐Ÿ˜‰
ktmrfs
wolfe10 wrote:
There are actually THREE "what can/should I use to inflate my tires" answers:
Nitrogen
DRY air (with air dryer to remove moisture from air)
WET air (you know-- those coin op machines with water dripping from the air chuck)
Nitrogen and dry air both follow the Ideal Gas Law (PV=nRT). For a given temperature change, there WILL BE a given change in PSI.
Wet air is NOT an ideal gas and will give more PSI change for a given temperature change.
yup, excellent summary.
And a common and easy way to remove moisture uses a permiable barrier will remove the moisture and remove most of the oxygen giving you dry nitrogen.
hence likely the nitrogen fill. But filling with dry air is for all practical purposes for most applications just fine.
2011 Keystone Outback 295RE
bikendan
sold tires for 10 years and this is the biggest scam the Tire Industry has ever come up with.:S
wolfe10
Nitrogen
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Bill_Satellite
For what we do, be it RV or car, this is just snake oil. If you find you need air in your tires fill them up anywhere air is available.
Can't we all just get along?
dave54
For ordinary vehicle use the advantage is negligible. If you can get the tires filled with nitrogen for free, then go ahead. Won't hurt and a very small benefit. If you must pay for nitrogen you will never recoup the cost over the lifespan of several sets of tires.
