spray lube on hitch????
BigSur2
I have another question that has probably been beat to death but I can't get anythign to come up in my searches.
Is it okay to use a dry silicone spray lube for my hitch ball and WD components? I've been using actual grease applied with a gun and then rubbed all over. Seems like overkill if I can just give her a quick spritz with some silicone spray. ???
BigSur2
2016 Jayco White Hawk 33RSKS
31 REPLIES 31
BigSur2
I just wear old clothes ๐Ÿ˜‰ And thanks for all the responses guys. As always, I end up where I started, so in this case, I think I'm gonna keep using my handy lithium grease / grease gun. Seems like the best protection for my hitch. I am NOT going to take my dealer's service guys advice to just carry a bottle of wd40 around with you everywhere. ๐Ÿ˜‰
BigSur2
Ryan_Elli1
Grease on the pants... been there before. When it happens and it will, use Lestoil to get it out. Funny story on how we discovered Lestoil. My wife washed her jacket with lipstick in the pocket. Her light blue jacket came out with bright red strips. Lestoil took care of the red strips.
2014 Cougar 29RBS(Kizzy)
2015 F250 FX4 6.2
Ryan, Elli, and kids
with Holly the Mini Schnauzer
BarneyS
The Reese ball lube used to be available at Walmart but I have not seen it lately. It does turn black however and will get on the clothes just like the other stuff. I had a jar that has lasted for about 6 years.
Plain grease worked just as well.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
BigSur2
SRockwood wrote:
downtheroad wrote:
Been using the stuff in this jar for years...Teflon.
One jar lasts forever.
This reminds me of a buddy who refused to tow without it:
After working on a racecar to get it ready all day, we start loading up to go. All of a sudden, my buddy stops the loading procedure and yells into the quiet night: "honey! Where's my ball lube?!?!?!"
haha...funny story!!! That looks like a good product....I assume it doesn't turn black and ruin clothes???? Can that be bought off a shelf somewhere???? Wally world???
BigSur2
BarneyS
๐Ÿ™‚
Barney
Not towing now.
BigSur2
Thanks Barney. You da man. Hope you are doing well. My hitch setup is still working like a charm.
BigSur2
BarneyS
ALL hitch manufacturers that I am aware of (except Andersen) recommend using some type of grease or lube on the ball and where the WD bars are connected to the hitch head.
Barney
Not towing now.
BigSur2
DodgeVoltage wrote:
ryhed wrote:
Never used anything and I never will. never had a problem.
Same here. No need to put anything on them. I've never worn anything out in MILES of towing.
Are we talking just the ball or the spring bars as well? I can't imagine not putting anything on the bars. Manufacturer's reccomendation.......?????? Seems to me that's a LOT of metal-on-metal movement to not use a lube.
BigSur2
DodgeVoltage
2010 Dodge 3500 Mega Cab Cummins Diesel DRW
2009 GMC 2500HD D/A Crew Cab
2012 Dutchmen 3795 Voltage Epic Package
2012 Smart Fortwo Passion
2017 Smart Fortwo Proxy
AD USAF 1996-2011 1700+ hrs E-3B/C AWACS
NYANG 2011-Present
K-State Wildcats!
ryhed
AlbertaNewbie
DBH_MI wrote:
Motorcycle chain wax works well too. Doesn't attract much dirt and doesn't wipe off easily onto clothing.
X2, sprays on, dries to a waxy paste and when it heats up it is somewhat liquid. Rarely comes off.
This stuff is subjected to extreme pressures on chain driven motorcycles and works great. Depending on type can be had for $5-20.
2014 Dutchmen 261bhs - 7200#'s loaded
2012 Ram 1500 SXT Crew Cab w/5.7L HEMI, 4x4 3.55 Gears
250w Conergy 250P 24v solar with tristar 45amp mppt charge controller
mkirsch
Nomad II
Nomad II
christopherglenn wrote:
C.B. wrote:
Try using Slip Plate. Spray on and dries. I use it on all the metal to metal sliding surfaces on my Pullrite Superglide hitch.
C.B.
They don't make slip plates for WD hitches.
Slip Plate, it's a kind of paint, with graphite impregnated so that it is slippery.
I painted up an old lawn mower deck that had problems with grass clumping with the stuff once. It helped.
SRockwood
DBH_MI
