Sticky waste tank valves
jimmycrack
On my RV. I have noticed the waste gate valves have become very sticky especially on the grey tank. I'm guessing the soap and cleaner build-up are causing the valves to gum-up and stick. I poured appox. 10 ozs. of baby oil down the sink drain into the into the grey tank after I emptied the tank. The valve now slides at the touch rather than pulling and trying to force the valve close. The black tank will get treated next when it's time to drain it.
9 REPLIES 9
JD_and_Beastlet
We use a rubber seal treatment we got at the dealership when we winterize. I like the cooking oil idea - much cheaper.
2008 Starcraft ST 2700BH behind 2013 Ford F-150 SuperCrew EcoBoost FX4.
Linked by ProPride 3P 1400.
restcure.ca
coolbreeze01
When storing, we put canola oil in the commode. Doesn't evaporate.
2014 Sandsport 26FBSL
tvman44
I too use baby oil or mineral oil, which ever I find first.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Bobbo
Be careful with this. Baby oil is a petroleum based oil, which will degrade rubber over time. A better oil to use would be a silicone oil.
Bobbo and Lin
CavemanCharlie
Thanks, mine are sticky too. I will give it a try.
1492
Moderator
Moderator
Moved from Forum Technical Support
GMandJM
Cool. Thanks for the tip.
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
Calicajun
Nice tip.
2014 Heartland Wildness 2775RB, 2015 Ram 2500 4x4 Mega Cab
2oldman
Excellent.
