I just went to camping world an was told there is no repair kit for thesaniconpump system anyone have any ideas,mine seems to be slowing down on pumping and makes a little noise once in while ,it is 6 yrs old.ed
Have you ever had it apart?....the motor should be taken apart and cleaned at least once every two years, more often if you or your camping partner(s) have long hair. Hair is the worst to get clogged in the blades. Simple process...take out the screws and pull it apart. Inspect the impeller (rubber) and clean the blades. Reassemble and you're good to go for another two years. The only fly in the ointment is the large gasket between the two body pieces. That gasket is pretty flimsy and is not sold individually. NAPA sells a roll of gasket material that you can make your own.....Dennis
We can do more than we think we can, but most do less than we think we do Dennis and Debi Fourteen Years Full Timing Monaco Executive M-45PBQ Quad Slide 525HP Cummins ISM 6 Spd Allison 2014 Chevrolet Equinox LTZ W/ ReadyBrute CLICK HERE TO VIEW OUR TRAVEL BLOG
