Sometimes FWD cars have wheel alignment settings such that front tires wear faster in trail (towing condition) than they do when serving as drive wheels. But not always. I've not yet towed my Fit far enough to know whether this matters. Actually, at 25,000 miles with tire rotations every 5000, I've not yet figured out "normal" wear, the OEM tires still have almost as much tread as they did when new.
2012 Base Fit. The Sport has quite different tires and wheels.
What about abnormal tire wear on Aspect 30J towing 2007 C-Rv. First trip out I noticed feathering on both front tires. We had minimum load on this trial run in our new RV. Rear Air springs set to 50PSI.
We have driven our Odyssey 125,000 miles and towed it 80,000 miles. We rotate the tires based upon the combined total number of miles, not just the driven or towed miles.
Dave & Kathy 2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike Fulltime 2007 to 2016, now halftimers Before you give someone a piece of your mind, make sure you can get by with what will be left. Our Blog National Parks Visited
Not unless you forget to unlock the steering wheel:B
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
