Thought it would be interesting to jot down the top ten things I've learned over the past 3-4 years (not necesarily in order) as it relates to this forum, and RVing in general. Im sure many of you can add to this list.
1) There is not much difference in quality between the various brands of trailers (perhaps with exception of Airstream). Pretty much all major brands use the same components, and have the same level of laborers (note I left out the word 'skilled').
2) Most people wrongly focus on TV manufacturers stated towing capacity, and assume that translates directly into how big a trailer they can tow. Newbies don't understand the Cargo capacity relationship. I was in that same boat, but researched it extensively before I even joined this forum.
3) In most cases, people over estimate their TV capability to tow the TT or 5er they want, and will search endlessly for validation that supports their theory.
4) Generally speaking, an extended warranty is not worth purchasing. Most issues are found during the first year and SHOULD be fixed under factory warranty.
5) Opinions on ST vs LT tires are as strong, if not stronger, that TV and weight recommendations.
6) RV's of all types depreciate heavily from initial brand new purchase. No standard on how MSRP is calculated or portrayed.
7) People tend to post questions, even if there are 10 threads of similar discussion, rather than spend time doing research, either on this forum or elsewhere on the inter-web. Note: This phenomenon is not limited to RV.net.
๐ RVing is a hobby, and costs money. If you are in this to save money on vacations etc, you are looking at it all wrong.
9) It is important to use the right tool for the right job. That includes the right TV for the right job. When you need the 'capacity' and safety margin and you don't have it, you will likely regret it.
10) It is important to inspect your trailer routinely. Check lugnuts each trip, test all safety components etc.. Your trailer is flexing, bouncing etc as you drive down the road. Things break regardless of how well they are put together... especially when towing.
Anyone want to add to the list?
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
