Tow bar
rfsod48
Which tow bar system is best choice? Fleetwood Bounder 38 N and Jeep Cherokee 2015 Latitude.
Roland,Linda and Matt Schwarz, LuLu, MoMo and Chewy
2005 Fleetwood Bounder 38N Catipillar C7
2015 Jeep Cherokee Latitude 4wd Drive II
Go Bucks!
13 REPLIES 13
dalerussel
We just chose the Blue Ox Avail tow bar. It is easy to set up, does not bind when unhooking and has a baseplate that is inconspicuous on our CRV when not in use. For a braking system we chose the SMI Stay and Play duo since it is hidden, only needs to be plugged in to engage and uses both brake lights and deceleration to activate. We also installed a fuse master so we don't have to pull fuses when the CRV is being towed.
traveylin
First answer the question, do you want the two bar mounted on the car or MH when not in use. I wanted it left on the motor home
Fiverwheel
I'll vote for the Ready Brute. All mechanical, trouble free and way less money to boot!
2006 34' Monaco Cayman
mowermech
I was very happy with a Reese fixed arm A-frame towbar on my Jeeps for many years.
Then, because I needed more than 5000 lbs. capacity, I got a used Roadmaster Stowmaster 6000 lb. capacity telescoping arm unit. Other than the added capacity and the fact that it folds up on the front of the truck, I am not impressed. In fact, I use it just like it was a fixed arm unit. It is easier that way, for me. But, I bought it, and the truck is set up to use it, so I'm stuck with it. It works, that's all that is necessary.
IMO, there quite simply is no "best"! there is only what each individual likes.
Good luck in finding one that YOU like!
CM1, USN (RET)
2017 Jayco TT
Bobbo
Another vote for the Ready Brute Elite. Tow bar/surge brake combo.
Bobbo and Lin
lanerd
Roadmaster tow bar, Unified brake system by U.S. Gear.
As mentioned, this is like which is better...Ford or Chevy. All depends upon what the replier is using.
Personally, I don't think you can go wrong with either Roadmaster, Demco, or Blue Ox. They are all equally efficient and all cost about the same. Best to buy the same brand tow bar as the brand of your base plates.
As for brake systems, there are many different types, so you'll need to do some research and decide which "type" is best for you. Then you can research the "type" you chose and pick the one of that type that suits your needs.
Good luck
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
RicJones
I like the Demco tow bar.
Crazy_Ray
Roadmaster X2
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
rvten
Have been using Roadmaster for years.
I have used my tow bar on 3 class A,s and this C. With several different a Toads.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
rk911
rfsod48 wrote:
Regarding brakes do you use a surge system or something like blue ox patriot?
we use the Unified Tow Brake from US Gear. Love it.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
rfsod48
Go Bucks!
rk911
best is in the eye of the beholder. we use and like the Blue Ox products.
Rich
'46 Willys CJ2A
'10 Jeep Liberty KK
Dutch_12078
"Best" is pretty subjective, but we've been very pleased with the performance of our ReadyBrute Elite combined tow bar and auxiliary brake system.
ReadyBrute Elite Tow Bar
Dutch
2001 GBM Landau 34' Class A
