Towing 2011 Odyssey
rbadger28
Just sold our travel trailer so we can purchase a class c. Done some research but cannot seem to get a straight answer when it comes to toads.
We already own a 2011 Honda Odyssey. Does anybody know what our options are when it comes to pulling this vehicle? Can it in fact be towed 4 down? If not, can it be towed on a dolly?
2 REPLIES 2
Dutch_12078
Apparently your Ody can be towed 4-down IF it has the 5-speed automatic transmission. The 6-speed must be dolly or trailer towed. REMCO says this about the Ody with 5-speed:
Officially from both Honda and REMCO the vehicle is not towable. However, we at Remco have a large number of customers who are flat-towing that vehicle behind their Motor Home and they are not having any issues. Follow the "Emergency Towing" procedures in the owner's manual to a "T" except ignore the restrictions and follow those procedures each and every time you tow. NOTE: If you choose to tow your Honda, and have any damage to the Transmission as a result, you will have to pay for that expense out of pocket. It is nothing that Honda or Remco will warranty. Also, it should be noted that Remco sells no aftermarket product (Lube Pump or otherwise) to make this car towable.
Dutch
2001 GBM Landau 34' Class A
1995brave
Check your owners manual under towing/ recreational towing.
