Towing an automatic car with all 4 wheels on the ground?
precioustime
I presently tow a 2014 KIA Soul manual shift behind my 24 ft Class C rv with no problem. I take off the emergency, put it in neutral and turn the key only I time. Can I do the same with an automatic transmission? I have called several KIA dealers but get different answers. I called the KIA plant in Georgia and they said no! Can I do something to the transmission to allow me to keep all 4 wheels on the ground? I do not want to use a tow dolly to lift the front 2 tires.
18 REPLIES 18
kjburns
There are lots of cars with automatics that can be flat towed. Pretty much all of them are from domestic manufacturers. I've towed a few Jeeps and currently tow a 2014 Ford Focus Titanium. The Focus requires the negative cable being disconnected, but a simple disconnect switch makes that a 10 second operation. It's very easy to hook up and go.
2019 Dynamax Isata3 24FW
MARKW8
I wasn't referring to fuses or turning the key. It was about lube pumps or drive shaft disconnects. Not everyone wants GM or Ford. I currently tow a Jeep Wrangler, probably as easy as there is to set up. It's not a car for everyone though.
Mark
Bumpyroad
lanerd wrote:
"Jumping through hoops". Interesting description of pulling a fuse and/or turning the key to ACC.
Ron
Yep, I always recommend not buying something that needs modification such as a tranny pump or disconnect, but some folks fuss if they have to pull a fuse (which can be automated) or start it every 300 miles. ๐Ÿ™‚
bumpy
lanerd
MARKW8 wrote:
lanerd wrote:
MARKW8 wrote:
Very few automatic cars can be towed 4 down, without going to something from Remco.
Mark
Mark, with all due respect, this is simply not true. Almost all GM auto trans vehicles can be towed 4-down as well as many Ford and Chrysler products. It's the import vehicles that an auto trans restricts towing 4-down.
Ron
Yep, I have a 2015 Chevy Malibu that can be towed. That said, It seems even Ford has backed off some models after saying it was ok. On the whole, there are a lot of mid size and smaller cars that can't be without jumping thru hoops or not at all.
Mark
The only Ford model I'm aware of that they said could be towed and then backed off of was the Escape, and that was only for a couple of years of production. That problem was the transmission that was co-developed with GM that was also installed on the Chevy Cruise. Both now have different transmissions.
We rented a Malibu last year... great little car.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
lryrob9301
AS per Remco Towing:
2014 Kia Soul + FWD I-4 2.0L cyl 6-Speed Automatic A6MF1/A6GF1
Notes
โ€ขMust be towed on a tow dolly. Please confirm in owner's manual.
No mention of lube pump availability. So your out of luck towing it 4-down.
MARKW8
lanerd wrote:
Mark
Ron
Mark
janstey58
I have towed my 2012 Ford Escape Auto AWD for over 10K miles no problems!
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
Bumpyroad
GMandJM wrote:
philh wrote:
... A driver must be in the towed vehicle to operate the steering and brakes.
Wow - that would be a deal breaker. ๐Ÿ˜‰
I think the real deal breaker is the part about a 1 mile limit at 30?mph or whatever.
bumpy
lanerd
Obviously what Philh wrote was NOT in the Recreational Towing section of the Owner's Manual. Altho, there have been times when my DW wanted me to be in the toad while she's driving the MH.
Ron & Sandie
TPMS: Pressure Pro
Bumpyroad
plenty of vehicles out there that can be towed 4 down without modifications, etc. Get one.
bumpy
GMandJM
G-half can always find a way to do things upside-down, inside-out or backward.
It's his Super Power!
lanerd
Mark
Ron
Ron & Sandie
TPMS: Pressure Pro
philh
Problem comes from the lack of trans fluid being circulated through the system. Some vehicles can get enough splash to protect the internal components. Your owners manual should talk about tow truck mile limitations. Should be able to project how it would flat tow based on the mfg recommendations
Here, I checked the owners manual
http://www.kia.ca/content/ownership/ownersmanual/14soul-en.pdf
Pay particular attention to 6-24 & 6-28
CAUTION - Automatic
transaxle
โ€ข If the car is being towed with
all four wheels on the ground,
it can be towed only from the
front. Be sure that the
transaxle is in neutral. Be sure
the steering is unlocked by
placing the ignition switch in
the ACC position. A driver
brakes.
โ€ข To avoid serious damage to
the automatic transaxle, limit
the vehicle speed to 15 km/h
(10 mph) and drive less than
1.5 km (1 mile) when towing.
โ€ข Before towing, check the automatic
transaxle for fluid leaks
under your vehicle. If the automatic
transaxle fluid is leaking,
a flatbed equipment or
towing dolly must be used.
BarneyS
Moved to Dinghy Towing forum from Towing.
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
