Towing
Ray_T_07
I have a 2018 Ram 2500 with the 6.4 liter Hemi with a tow rating of 15,563 lbs. My question is I am looking at a 5th wheel that has a gross weight of 15,500 and the dry weight is 13,469. Would this be something I can tow? Also too this 5ver has a hitch weight of 2184
11 REPLIES 11
IdaD
BarneyS wrote:
Airbags or Timbrens are not going to change the load on the rear axle and will not help with his overload situation. All they will do is pick up the bed of the truck. The axle loads will remain the same.
Barney
Itโ€™s the same axle. 11.5โ€ AAM which I think itself is rated for about 11k lbs. The bags/timbrens address the springs which is the only difference. Iโ€™m pretty sure GMโ€™s HD trucks use this axle as well.
2015 Cummins Ram 4wd CC/SB
bikendan
Barney
THIS^^^^^^
BarneyS
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
IdaD
jaycocamprs wrote:
I wouldn't pull that much with a 2500 truck. You will most likely be over GVWR & RAWR once the trailer is loaded. A SRW 3500 would do better with the weight.
Yes by 500 lbs on the rear axle, unless OP springs for airbags or timbrens. You are correct that the gas engine is marginal.
jaycocamprs
I wouldn't pull that much with a 2500 truck. You will most likely be over GVWR & RAWR once the trailer is loaded. A SRW 3500 would do better with the weight. The 6.4 Hemi would likely do ok on flat ground and at lower altitude. But for any real grades the diesels will way to go. I like having more truck than needed, makes for a easy tow no matter what.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
Ray_T_07
Thanks guys for the comments and sorry for the duplicate post..new to this game of forums!!
IdaD
It would be a very slow tow at times with the gas engine and the mileage would be awful but I don't see the weight being a huge issue as long as the truck has 18" or 20" tires to get the 6500 lb RAWR. Add bags/timbrens and it should be good up to the 3500's 7000 lb RAWR (not on paper, but real world). The fact that OP lives back east would help in terms of the types of grades and elevation he would typically experience. Just my two cents.
APT
Agreed with the answer. One followup question you may have is: How much can/should you plan to tow with listed vehicle? If you have 4.10 axle, I'd shoot for 10k dry max.
2017 Subaru Outback 3.6R
Bobbo
If you don't like the answer, rephrase the question. You didn't even rephrase the question.
Bobbo and Lin
Old-Biscuit
Discussion yesterday.....
NOPE!
donn0128
Please read the forum rules. You asked this exact same question yesterday and got the correct answer then.
