TV Antenna
Nolan
Anyone using one of these on your RV and what do you think of it?
http://mini-state.com/
8 REPLIES 8
SCVJeff
CavemanCharlie wrote:
My computer anti-virus program won't even let me click on the link in the OP's post.
Thats because it's the true definition of JUNK
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
CavemanCharlie
TXiceman
best all around antenna for an RV is the Wineguard Sensar IV. The Jack will not perform as well in the boonies
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
DutchmenSport
Here ya go. click here.
I always said, just a bare wire sticking in the coax cable hole in the TV works as good as anything!
dodge_guy
I have a Jack antenna. One of the best $40 I`ve put into our TT! picked up 10X the station my old antenna did.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
TyroneandGladys
I have a Lava OmniPro HD-8008 and love it. Have it laying in the cab over and it does fair. Have piece of aluminum conduit that I can attach it to that is clamped to the ladder then it does excellent. Can set this up in under 5 minutes and no aiming required. Have been able to pull in stations that the standard bat wing RV antennas wont. HD-8008 link
Tyrone & Gladys
27' 1986 Coachmen
SCVJeff
It's actually a directional antenna and it is the biggest piece of junk ever made. These are standard issue on ENG news trucks and they destroy themselves very fast, I know, I used to fix/ replace them. They are literally built with styrofoam and tape. Buy one and you'll see.
Buy a Batwing or a Jack
Jeff - WA6EQU
rk911
that's nothing more than a low-profile, Omni-directional antenna. it may work well if you're in an area where the TV signals are strong...usually an urban area. but it may be a different story out in the boonies.
there are two basic factors to receiving a watchable TV picture. a good receiver and an antenna that can receive the signal. TV signals are, basically, line-of-sight. that means anything that gets between the transmit point and the receive point (your antenna) will affect the quality of the signal. trees, topography, other RV's etc. the farther away you are from the transmit point the greater the negative effect. the higher in the air you can get the antenna the better off you will be.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
