TV Pulls to right when hitched to trailer
sato4000
I have a 30 foot travel trailer. I use a equalizer weight distribution hitch with it. The alignment on my TV is fine until I hitch a trailer to it then it pulls to the right. Could this be something with the hitch? Loaded or empty it does this and I've made sure the tire pressure is fine on both the TV and the trailer.
6 REPLIES 6
CampingN_C_
My truck was doing that also. Slightly noticeable unloaded but VERY noticeable with the trailer. I knew it was my truck because it did it with different trailers. I've replaced the front brake lines and so far I haven't felt it (knock on wood).
Brake pedal feels MUCH better too my the way!
2018 Ram 3500 DRW CCLB Aisin 4.10 4x4
2018 Jayco Talon 413T
B&W Companion
carringb
Is the truck lifted? Is the front end returning to un-hitched height after you hook up the Equalizer bars?
2014 ORV really big trailer
2015 Ford Focus ST
Rumblejohn
Check that the brackets for the spring arm chains are even distance from the hitch ball. If they are not even, when you tighten the spring bars it will try to center itself.
2008 F-150 4.6L 3.55
2013 J-Flight 26BH
EAZ-Lift 1000/10000
Prodigy 3
sato4000
Thanks sounds like I will have to take it in to get checked.
the_bear_II
Trailer axles out of alignment maybe due to a curb strike or not setup properly at the factory.
downtheroad
Maybe trailer brakes on one side are dragging some??
just a guess.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
