Water Hester leaks at times
Cecilt
I have noticed that my water heater will leak from the pressure relief outlet. Is is normal for this to happen on occasion. It is not a constant leak. For example. I opened one at a time a hot waters spigot in the camper and nothing leaked on the exterior pressure relief. Finally some water would come out after running enough water. It does stop. Not a lot of water but enough to see in the bottom of the lip behind the outside water heather access panel. It will do it this sporadically. Never constant and never a puddle of water overflowing down the side of the camper. Tks
11 REPLIES 11
Cecilt
Thanks for all the tips. I turned off the city water, flipped the pressure relief valve and let water come out until it sopped. Reconnected to city water and no issues the rest of the trip. Must have needed that air pocket. Tks
JEBar
if none of the above recommendations work, the valve may need to be cleaned or replaced .... residue can collect in the valve and cause a leak through one of the rubber seals .... I have seen cleaning a pressure relief valve with a product like CLR solve the problem .... if that doesn't work, the valve itself may need to be replaced
Jim
'07 Freightliner Sportchassis
'06 SunnyBrook 34BWKS
Old-Biscuit
Air pocket.......air pocket....air pocket
Water can not be compressed...........air can be compressed
No air pocket.....PRV weeps
nomad297 wrote:
Now, if your temperature is at or above 210 degrees, there's nothing you can do except have a professional service it, but for the short term, work out which fuel mode (electric, gas) is causing the high temperature condition and make sure the heater is set to the mode that will not overheat the water. Hopefully one or the other will work properly.
Sure there is......replace the set of t-stats.
Normal t-stat should stop heating at 130*F or 140*F
AND the ECO (High temp t-stat) should shut down heating (if normal fails) at 170*F or 180*F (depending on which brand of water heater)
That is IF WH is overheating and not just LOSS OF AIR POCKET
Johno02
We installed a new Dometic water heater last year. It has always leaked about a cupfull from the pressure relief each time it cycles from cold to hot. I called Dometic and was told this is normal for their units to do this. Whenwe get back home, I will try replacing the valve with a new one from another manufacturer if there is such a thing. Does not seem like a normal thing to me, more like an excuse for a inferior and poorly made product. Wonder if I can get one from China??
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
nomad297
This happens when the pressure reaches 150psi or when the temperature reaches 210 degrees. Usually, though, with an RV water heater, it is the high pressure that causes the relief. If this is something new, it is best to work out which of the two conditions is causing the relief. You can do this with a pressure gauge and a thermometer, but usually you can tell which it is by the way it is discharging -- a short discharge usually indicates a pressure relief and a long, continual discharge usually indicates a temperature relief -- this is assuming that your source water pressure is less than 150psi, which it almost always will be.
When the water heats, the system pressure increases, no matter what you do. Some systems will increase on the hot side only and some will increase on the cold side, also, depending on the presence and/or placement of check valves. The amount of reserve space (air pocket) in the tank should be maximized and maintained to minimize the pressure increase when the water is heated. That's the best you can do without installing an expansion tank.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
Dog_Folks
It depends.
The owners manual for my heater says "seepage" from the pressure relief valve is normal.
Our Rig:
2005 Dodge 3500 - Dually- Cummins
2006 Outback 27 RSDS
We also have with us two rescue dogs. A Chihuahua mix & a Catahoula mix.
"I did not get to this advanced age because I am stupid."
Full time since June 2006
avan
Buy Hester some Depends? :B
www.putt10.net
downtheroad
Water Heater Air Pocket:
Shut off the water supply, open the relief valve until water stop coming out, close it, turn the water supply back on.
This will reestablish the air pocket in the water heater, giving the water some place to expand to when it is heated.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
pianotuna
Nomad III
Nomad III
Hi,
Let the tank cool.
Turn off the pump or disconnect from shore water.
Drain some water out.
Let us know if this fixes the problem.
Regards, Don
tvman44
Need to restore the air pocket in the tank, common problem. Look up the owners manual for your tank for procedure, very simple procedure. 🙂
Papa Bob
Husky 16K hitch, Tekonsha P3,
