Weak Brakes
climb_on
I have a 2020 No Boundaries travel trailer with a Lippert torsion axle w/ 15" wheels. The brakes are pretty weak even with the camper empty. I've towed numerous campers so I understand how the brakes should feel. I have my controller maxed out and on max boost. I just gave a quick visual inspection and there are no obvious issues. How do I figure out what is going on? Some sort of voltage test?
I bought the camper used, so it's not a thing for the dealer.
2020 Forest River - No Boundaries 19.8
Upgraded w/ Hensley Cub...
2013 Toyota Tundra Crewmax
Upgraded w/ Rear Sway Bar, Heavy Duty Shackles & Bushings, AirBags, LRE Tires....
22 REPLIES 22
JIMNLIN
Good ideas to work on.
Another is many trailer mfg use some type of clamshell wiring connectors. Over time and miles water corrodes those connections to the point proper amps doesn't reach the magnets even though a dwell meter says 12v.
When I was on the road and put a new or used trailer in service the first thing I did was R&R the brakes/bearings/suspension and removed all clamshell connectors and bad or smallish wiring. I soldered all joints and made them water proof as much as possible. This ensures full amps from the controller to all the brakes.
Flute_Man
You might just jack up each wheel apply the brakes and see if you can turn the wheel by hand.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
climb_on
dodge guy wrote:
My 07 had a similar problem. My issue ended up being weak magnets in the brake assemblies! I replaced those and the braking was unbelievable!!!! Between the truck and trailer it would stop very well.
Just something else to check.
How did you determine that? Or did you just swap out the part and found it worked?
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
climb_on
BarabooBob wrote:
First adjust the brakes. If that does not give you the braking that you think you should get, look at the wires that are used on the trailer brakes and see what gauge wire was used. I have seen some pretty wimpy wires on some trailers.
Thanks. Not sure why adjusting them didn't occur to me...guess I assumed since it was new. Will start with that.
When inspecting, I thought those wired looked pretty light.
Mike134
What they said above plus pull the drums and check the shoes for grease contamination, etc. Plus since you bought it used a good time to check the bearings, clean and re-lube so you know the maintenance history.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
BarabooBob
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
ScottG
I would adjust the brakes first.
