โFeb-19-2014 07:48 AM
โApr-02-2014 07:51 PM
โApr-02-2014 01:13 PM
mrekim wrote:myredracer wrote:Fisherguy wrote:
Wow, really, an inch movement?
Yes, if not a bit more. That's one big contributing factor to cracks in the I-beam immediately above the spring hangers. I believe there is someone else on this forum that understands this phenomena.
If you were going to attach a magnet mounted camera to the frame to view this flex, would you attached it to the main beam looking to the hanger. So looking directly back or forward?
โApr-02-2014 12:56 PM
โApr-02-2014 12:15 PM
โApr-02-2014 12:06 PM
โApr-02-2014 07:39 AM
โApr-02-2014 07:34 AM
jgos929 wrote:
Well I got the new 2900# leaf springs in. I also installed Mor/Ryde cross members on the front and middle hangers. I couldn't fit one across the back hangers because my black/grey water plumbing was in the way. So I welded in some flat bar on the outside of the ibeams and connected it to the flanges (as seen on here. I found 2 more cracks, one on each side above the rear hangers. These were bad you could actually see through them so I laid a bead over those. I worked on this thing for 7 hours and it beat the hell out of me but all in all I feel good about the repairs I did. I loaded up my sxs and with the new springs she doesn't sit near as low as she did before. With the new cross members and bracing the wheels should stay in line. I didn't notice any flexing during sharp turns or backing it in to its storage spot like I did before. We have a trip planned for next week and I feel good about it. When I get back from that I plan to add a few more pieces of flat bar for bracing and double check the cracks and then I'll be done with it officially. Thanks again for all the help on here guys.
โApr-01-2014 05:09 PM
โApr-01-2014 02:50 PM
โMar-18-2014 07:56 PM
โMar-18-2014 07:01 PM
jgos929 wrote:
I ended up going with the Mor/Ryde xfactor crossmembers instead of welding in steel tubing. It increased my cost significantly but I'm not worried about that. Loaded up on flat bar today so I can weld in some support on the I beam. I also ordered new equalizers and 4 new 2900# springs. Parts should be delivered this week sometime and I hope to make the repairs this weekend
โMar-17-2014 06:33 PM
โMar-11-2014 02:10 PM
โMar-09-2014 01:14 PM
MM49 wrote:
The trailer might of had the LT tire change done on it.
MM49
