What kind of small/medium truck can be towed
EydieG
We have a 38 ft Dutch Star diesel pusher. We have been towing a Jeep Grand Cherokee for about 7 years but now thinking about a truck. Not a big truck, but one that can pull our 19ft boat (not at the same time it is being towed, of course). What kinds of trucks can be towed 4 down without much effort? our Jeep Grand Cherokee has been so easy to hook up to our blue ox, we are kind of spoiled.
Thanks for any suggestions!
Brand new owners of a 1999 Newmar Dutchstar DP
9 REPLIES 9
BruceMc
Grit dog wrote:
^Hey are you brucemac with the Prostar 205V?
No.... Prostar 205V?
I'm "BruceMc", not "brucemac".
2016 Forest River Sunseeker 2250SLEC Chevrolet 6.0L
mowermech
dodge guy wrote:
Any 4WD 1/2 ton with a N position on the T-case. A Chevy Colorado can tow that size boat as well as a Jeep Gladiator.
Keep in mind that not all Hi-N-Lo transfer cases can be towed four down! There are a few that will not properly lube the bearings and seals when being towed in Neutral. I once had a Jeep CJ7 that could not be towed without modifying the transfer case. I sold it.
ALWAYS read and follow the manufacturer's recreational towing instructions!
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
Grit_dog
Navigator
Navigator
BruceMc
We tow a 2012 GMC Canyon 4WD:
Dead simple setup when readying to tow.
Hook it to the tow bar, then flip a switch to enable supplemental brakes, as I installed the Demco Stay-N-Play braking.
To put the transfer case in neutral, turn on the ignition, step on the brakes, put the gear selector in neutral, then hold 2H and 4L together for 10 seconds. After the N indicator lights up, put it in park and pull the key.
Done.
The 2nd Generation Colorado/Canyons are a bit more involved, but they are towable, as is the new Rangers.
As Way2Roll mentioned, consult the towing guides, then download the user manuals for those vehicles you are interested in. If the towing guide says a vehicle is towable, then verify as the manufacture's user manuals are the definitive guide.
Lwiddis
Check with the manufacturer on-line before you buy…and carefully.
bikendan
Should be moved to the Dinghy Towing section
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
way2roll
Navigator II
Navigator II
Dinghy towing guides
deltabravo
2015+ Chevy Colorado GMC Canyon can be flat towed.
I have a 2017 with the 2.8L Duramax. Powerful little truck.
I towed this with it across WA State when I bought the truck and got 19-20 mpg.
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
