Wheels don't spin silently, brake issue?
kohai
The other day I lifted my trailer up to do the ez-lube thing on the wheel bearings. I noticed that when lifted, when I rotated the wheels/tires by hand there was a slight noise. They don't spin silently.
Does this mean my brakes aren't adjusted right?
2014 Primetime Crusader 296BHS
2015 GMC 2500HD Denali
22 REPLIES 22
Fulltimer50
๐Ÿ˜‰
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
harold1946
Fulltimer50 wrote:
Disc brakes do not use magnets. They are just like on your car but use an electric pump to make the pressure to activate.
Correct. Sorry bout that.:o
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
Fulltimer50
George
harold1946
There are two types of electric trailer brakes. Drum and disk. the drum type is adjustable, the disk type is not. Both employ electromagnets.
Harold and Linda
W-22 Workhorse 8.1L
Explorer Sport toad
Turtle_n_Peeps
Vulcan Rider wrote:
Lynnmor wrote:
These trailer brake magnets are a rather new idea, only been used for the past 88 years.
Would these "magnets" used in electric brakes also be called solenoids sometimes ??
No, different deal.
Here is a pretty good video for you on hew they work.
~ Too many freaks & not enough circuses ~
"Life is not tried ~ it is merely survived ~ if you're standing
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Vulcan_Rider
Lynnmor
history
Vulcan_Rider
RAS43 wrote:
I think Vulcan is trying to pull your chain guys!! :E
Just stop it please.
Nothing could be farther from the truth.
I have zero experience with electric trailer brakes.
For the others who answered:
Thank you for the simple and straight forward information.
Vulcan_Rider
3oaks wrote:
Yes. You can learn something new every day. Never too old to learn.
Absolutely.
Sometimes you even re-learn stuff that you have long since forgotten.
RAS43
3oaks
Vulcan Rider wrote:
momentum rv wrote:
Yes, magnets on brakes... On drum brakes the magnet rubs the drum constantly, so you will hear a slight scr a ping noise even if brakes are NOT adjusted properly.
Is this a trailer thing ?
Because I've never seen a brake with magnets in it....ever....and I've seen a LOT of brakes.
momentum_rv
Yes, anytime you have electric drum brakes you have an electro-magnet.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
RVhiker
Yes. The magnet when it has current going through it is attracted to the inner face of the drum. As the drum rotates, the magnet is dragged along and pulls a lever to apply the brake shoes. It's how electric brakes on a trailer work. It may s c r a p e a bit without current flowing.
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
Vulcan_Rider
