Why run toad engine at every fuel stop?
TheLuvShack
Why run the toad engine at every fuel stop?
Is this recommended to keep the battery charged or lube the transmission or both. My toad battery charges through the umbilical cord. Will I damage the transmission by not running the toad engine for the recommended five minutes?
"If the women don't find you handsome, they better find you handy". Red Green
Daryl
18 REPLIES 18
Lwiddis
Theluv, rock and I didn't slap you. We said you were dead wrong not to follow the vehicle manufacturer's guidelines...which you didn't want to hear.
GrampaR123
Good point.
In our case, I'm fortunate that my wife is a night person and doesn't mind handling the night "shifts".(pun intended)
traveylin
start it every 8 hours, how do you schedule it for the evening and midnight shift
GrampaR123
rockhillmanor;
FYI, our 2013 Honda CRV manual says to start it every 8 hours. Nothing at all about miles.
TheLuvShack
SLAPDOWN by lwiddis and rockhillmanor. I just asked a question. CHILL!
Daryl
rockhillmanor
Lwiddis wrote:
"I get 600 miles on a tank of gas and travel usually 200 miles per day. What is the logic in running the toad at a gas station every third day?"
If you are one of those rare individuals who know more the the vehicle manufacturer, be my guest and don't run your toad, void any warranty you have...with my compliments!
X2 !
Every manual instructions I have seen states the start up requirements in MILES not days.
My toad manuf. stated to start the toad every 250 miles. And come on it is not a big deal or inconvenience.
Lwiddis
TheLuvShack
Thanks for the comments.
Daryl
j-d
Automatic transmissions used to have a "rear pump" that would be turned by the driveshaft when the engine was not running. That made it possible to push start these vehicles. Cheaper to eliminate rear pump and used a "front pump" coupled only to the engine. No push start and NO LUBE to the transmission when being towed.
Many manual transmissions have gears which the driveshaft can spin to sling lubricant into bearings etc. when towed in neutral. Some don't, so...
The engineers build a calculated risk into the owner's manuals for some transmissions and ask us to put lubricant into critical places and then replace it every so often with a procedure they spell out for us. In that manual...
rockhillmanor
sgip2000 wrote:
The reason for this is to keeps the trans lubed.
Ding ding we have a winner!!
X2
It is to lube the trans on some models.
What I did find out on my toad after 4 years of towing it and starting it every 200 miles as stated. The last trip I was so close to my destination/the 200 miles, I blew off starting and running it.
When I got there the battery was dead. Soooo on mine it not only lubed the trans but unknown to me it was also charging the battery too. :R
sgip2000
traveylin
DutchmenSport
You must have an Chevy Equinox as your Toad. If so, yes, run the engine as recommended.
K_Charles
My manual says I don't need to do that so I don't. If it said to, I would.
