Yet another "Do I have enough truck?"
youwillforget
9 REPLIES 9
youwillforget
JIMNLIN
op wrote:
I posted up my numbers, Trailer 5,100 dry weight 7,500 GVWR (unknown pin weight) Truck GVWR 10,000, GAWR FRT 4,100, GAWR RR 7,500, 10,000 trailer 5th wheel or WDH. I cannot find a CGVWR for the 97 C3500 as equiped. If the GVWR of 10,000 on the door sticker is in fact the CGVWR then 7,500 max trailer is to big because I weigh over 250 and the 35 gallons of fuel weighs 210 the hitch has weight, so 7500 trailer 500 for me the fuel and hitch only leaves 2,000 for the truck. I need to get the truck fueled and get the family in it and get to the scales. Do I get 10,000 GVWR for the truck and I can tow 10,000 for a combine total of 20,000 GVW as I interpret the information I have.
Trucks do not have a GCWR number stickerd nor is it a requirement to have one.
Some truck facts from your numbers.
'97 3500 DRW GM truck with a 454 big block
has a 10000 lb GVWR
has a 4100 FAWR
has a 7500 RAWR
tow ratings run up to 10000 lbs
These numbers are all you need.
I have a '98 3500 DRW 454 crew cab 4x4 4.10 gears with a 10000 lb tow rating. I use this truck custom hauling cattle/horses pasture to pasture or to sales barns with a 15.5k GN tri axle (7k axles)stock trailer.
This trucks rear axle weighs 3040 lb which leaves 4400 lbs for a payload. As I mentioned trucks don't carry a gross combined weight rating (GCWR) however a 10k tow rating and a 10k GVWR can give you a 20k GCWR.
When you scale the truck keep a copy of separate front and rear axle weights in the glove box. A single gross weight with no axle weight numbers is worthless number for a truck towing a trailer.
mkirsch
Nomad II
Nomad II
It got off topic because you mentioned it. If you wanted to talk exclusively about weight you should have left that part out. It's called directing the conversation.
You can't possibly be serious at this point.
Your DRW truck should weigh around 6500lbs empty, as it's a '97 and a 2WD. It has a 10,000lb GVWR. That leaves you 3500lbs of payload capacity for the trailer's pin weight and your family.
The trailer has a 7500lb GVWR, so worst case scenario if you load it with lead ingots and actually hit that 7500lb mark, and it has a worst-case 30% pin weight, you have a pin of around 2100lbs.
3500 - 2100 = 1400lbs left for you and your family. It is highly likely that the pin weight is much less than that, though.
The only way you will be over GVWR is if there are six of you and you all weigh more than an average of 240lbs each.
The trailer you are looking at is lightweight. You have plenty of truck, so either stop worrying or let us in on the joke.
youwillforget
crickeydog
youwillforget wrote:
1. I am looking at Craigslist and find a 26' 5er in my price range. I call, the lady is upfront and honest says it had a little water damage when they bought it.
2. So do I have enough truck for this trailer?
1. IMHO: Any RV with water damage not repaired by a reputable repair shop with documentation, pic's, and warranty towards the repair, I'd leave that sucker flat. There's about a hundred thousand other RV's out there without water damage for you to pick from.
2. Yes
Happy camping!!! See y'all down the road!!!:)
USAF RETIRED 02/1992
DOD RETIRED 04/2014
D/W US GOV/DOJ/DEA RETIRED 10/2010
PULL DOG:
2006 GMC 3500 CC DRW D/A LBZ 4X4 SLT
2004 HOLIDAY RAMBLER PRESIDENTIAL 30' SCD 5'ER
jerem0621
More than enough TV...just make sure there is no more rot...
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
youwillforget
Artum_Snowbird
Yes, if the brakes on the Jayco are working fine. No if they are not.
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
newman_fulltime
plenty you are good to go
