03 keystone 298BH water heater switch
Itisme
Any ideas where to find the electric on - off switch for the water heater on a keystone 298 BH?
2014 Forest River Wildwood Haritage Glen 300BH
1996 C2500 454, 74000 miles (making due for now)
1996 32' prowler (retired)
3 REPLIES 3
Itisme
This unit doesn't have a main control panel like some, nor does it have a switch in the water heater box like my last two. I didn't think about looking in the breaker box, so I'll check there just in case. I've looked all around and just haven't bumped into it yet.
You_can_t_take_
First.. make sure there is water in the HWT. Then, if it is a Suburban HWT take off the outside cover. Look for a small switch inside the compartment and flip it to 'ON'. If your breaker is on you should be good to go!
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: 2002 Cougar 276EFS; 2005 Laredo 29GS; 2002 GMC 2500HD Ext Cab 4x4; 2015: 2006 Class 'B' Chateau Citation; "(Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
OpenRangePullen
should be with the central control pane usually located in a cabnet next to the main entrance door.
2013 OpenRange Roamer 395bhs
2022 F350srw Limited, tower
2021 F150 Platinum Hybrid, daily
2002 Accord V6/5spd, project
2014 Kawasaki Concours
