Hello everyone..
It appears the mounts/straps for the fresh tank in this unit are sagging horribly. Enough that the enclosure and the tank are almost resting on the axle's. This appears to be a simple remove and replace straps but I am curious about future sagging. I have been told that the design of the straps are such that when the tank begins to expand as it is filled the straps allow the tank to sag slightly.
Question is do I attempt to replace the straps similar to the way Keystone originally supplied or do I do it my way which is using flat steel as supports..
Pros cons?
Thanks
