โFeb-29-2016 07:30 AM
โMar-08-2016 01:00 PM
harley-dave wrote:MEXICOWANDERER wrote:
Something is "King-Size" screwball here.
Rectifiers can fail OPEN CIRCUIT. No electronic connection. Just like taking a wire off. No power.
Rectifiers can fail SHORTED. No voltage drop. Just like hooking up a jumper wire bypassing the rectifier.
If the house rectifier shorts, the alternator could care less it's gonna continue to send voltage that's one volt too high to the center stud of the isolator. The chassis gets "corrected" voltage.
The other rectifier however is no longer a rectifier. Alternator voltage is sent directly to the house batteries. And guess what? It's one volt too high.
At this point if it fails 'shorted' your main concern should be the alternator is sending AC power to the battery/circuit, not DC anymore. It will go bad very fast in this scenario.
Dave
โMar-08-2016 12:10 PM
Makin' Do wrote:
OP here. Thanks for your input, some from those that know as little as I do and those that do know what they are talking about.
I checked the voltage output at the engine battery and the connection point where the house battery is located just to make sure I read the numbers right. At the engine battery voltage was 14.4 steady output (same as the digital voltmeter on the dash) and at the house battery it is indeed 15.4 to 15.8, bit of a fluctuation. Have a new isolator in the shop so I'll swap them over the weekend when the weather warms a little and see if there is difference at the house battery.
400 watt inverter is indeed out of the question. I do have a new, never out of the box Duracell 1500 watt inverter (modified sine) that I bought six or seven years ago that I forgot I had (wife had to remind me). I think the only reason I bought it was the price, $63 on Amazon. Never had a real plan for it.
Read the owners manual, all 67 pages, and on page 67 it said "do not hook up the invert to a battery isolator". So much for a plan. Then again, Mr Wizard said it just might be possible. Maybe I could go with solar panels as suggested.
โMar-08-2016 07:48 AM
โMar-03-2016 07:30 AM
โMar-03-2016 07:28 AM
โMar-03-2016 05:11 AM
โMar-02-2016 09:08 PM
โMar-02-2016 07:32 PM
โMar-02-2016 05:27 PM
โMar-02-2016 11:22 AM
โMar-02-2016 08:52 AM
Makin' Do wrote:
OK , I'll admit to being no expert when it comes to electrical matters, so put this question under the topic "will this really work?"....... So here's the real question: can I connect the isolator output to a 400 watt inverter and run a Progressive Dynamics 9245 on 110 ac from the converter and let it manage the batteries just like it would be doing if I were hooked up to shore power?
โMar-02-2016 05:21 AM
โMar-01-2016 04:34 AM
โFeb-29-2016 10:41 AM
