โMar-07-2023 06:50 PM
โMar-08-2023 06:34 AM
ewarnerusa wrote:This is correct. Acid batteries and huge 12v draws don't always work so well. Not only is 4/0 cable difficult to work with, batteries and connectors will start to heat up drawing hundreds of amps over more than a few minutes.
Or from another angle, a higher DC inverter won't be as negatively impacted by the voltage sag when you really draw down hard to meet a big AC load like microwave or even go for the air conditioner.
โMar-08-2023 06:24 AM
โMar-08-2023 06:14 AM
TurnThePage wrote:
I'm very near to picking up a new travel trailer that I intend to pack with solar and LiFePO4 batteries. It's a 30A 120VAC RV. I understand the electrical wiring advantages of the higher DC voltage configuration, but what does everybody do with their 12v appliances?
I'm hoping for around 1500 watts of solar and no less than 1000Ah of 12v batteries. Is there a good reason not to stick to a 12v configuration?
โMar-08-2023 06:05 AM
โMar-08-2023 05:07 AM
wa8yxm wrote:I have 835w of solar so I don't care about efficient. Conversion losses are tiny compared to my usage.
so your most efficiecent install will be 12 volt all the way..
โMar-08-2023 04:45 AM
โMar-08-2023 02:38 AM
โMar-07-2023 07:58 PM
rk911 wrote:I absolutely agree!
i'm an old fart and have always tried to live by...keep it simple, stupid. the more wonky a system, the more headaches it will cause.
2oldman wrote:THAT'S the info I was looking for! Thanks! I figured stuff like that was available, but was in danger of drowning in data when perusing their website.
Victron 48 >12v converter. I got the 30a size to handle slides and jacks
โMar-07-2023 07:40 PM
โMar-07-2023 07:35 PM
โMar-07-2023 07:33 PM
โMar-07-2023 07:21 PM
