12v Constant DRAW
honestbest333
Hi guys,
I have something 12v draining my batteries overnight. I have everything shut off on the camper, and it still drains them over night. Just put in new batteries as well. Still drains them.
How do I start trouble shoothing this 12v electrical system to see what is causing the drain?
20 REPLIES 20
CA_Traveler
BTW Some of my battery loads cannot be turned off per mfg design. A switch on the battery terminal solved that problem.
2014 Grand Cherokee Overland
Bob
fitznj
Remove all 12v fuses from the distribution panel;
Take a multi-meter and put in the mode where you can see if
a circuit is drawing a current (usually no more than 10A);
Test each fuse and find out which circuit is drawing the current.
Now trace back to the appliance; I had the same issue and it turned out
to be the smake/CO2 detector and the fridge (even if it was off);
My batteries would drain in < 2 days;
Also - good point about the break away switch
Gerry
CA_Traveler
A DC clamp on ammeter is a very useful RV tool.
Bob
BFL13
If your "camper" is a trailer, check that the emergency breakaway switch plug has not been pulled out. If it has, plug it back in (needs to be turned just right so it goes back in).
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
1995brave
Make, model, and type of RV would really help zeroing in on your problem.
LittleBill
removes fuses from the distribution panel one at a time till the draw stops,
if that doesn't work, start removing wires at the battery one at a time.
