12V plug in for inverter
joebedford
Nomad II
Nomad II
Anybody else notice that if you draw near the max rated power for your inverter that the ciggy plug cable gets QUITE hot?
10 REPLIES 10
SoundGuy
1775 wrote:
These little inverters are not intended for what some want to power with them.
But still (try to) do it anyway. :S
For those who do want to do it right the solution is simple - just refer to a DC Wiring Chart like this that will tell you what gauge and length of cable is required for the maximum load you intend to draw. Since I (current in amps) is calculated by dividing P (power in watts) by V (volts, in this case a nominal 12 vdc) it's easy to calculate the correct wire gauge - e.g. a 300 watt inverter drawing full load would draw 300/12 = 25 amps. Look at the chart and that will tell you what gauge cable you need for the length you want to run.
2012 Silverado 1500 Crew Cab
1775
We had a fairly good inverter that not only caused the 12 volt outlet to get hot but also the inverter itself (which had a fan) got very hot. These little inverters are not intended for what some want to power with them.
Roadtrek 190 Popular 2011
Meryl and Me Hit the Road
Ron3rd
That's why I hard wired my 300w Samlex PSW inverter. Came with the plug, but I threw it in a drawer.
Equilizer Hitch
Honda EU2000
RoyB
It will melt your solder on the connection. I wouldn't do that unless you get a matched BLUE SEA PLUG and SOCKET rated for a specific current rating.
All of my battery connections are using terminal lugs just for that very reason.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
pianotuna
Nomad II
Nomad II
If it is a 300 watt inverter it would love to draw 30 amps running flat out. Cigarette lighters were never intended for that sort of load.
Regards, Don
time2roll
Yes just as expected with any circuit drawing near max rating.
Get some #6 wire and a 50 amp connector and everything will cool down.
MEXICOWANDERER
I've seen them smoke and catch "smolder" so it isn't merely annoying.
MrWizard
Moderator
Moderator
being strictly a power related question
it was moved from technology corner
I can explain it to you.
1997 F53 Bounder 36s
2oldman
yes
kaydeejay
Ciggy lighter outlets are usually rated for 10, maybe up to 15amps
That translates to 120 to 180 watts.
MOST inverters are going to push that limit so yes, they will get hot! What is the rating on yours and what are you powering with it?
Inverters (other than very small ones) SHOULD be hard-wired (with a fuse) direct to the battery with heavy wiring to handle the current draw.
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
