130 psi compressor for winterizing?
Beau_Bo
Hi - looking at at a Viair 400p compressor to carry al0ng for airing up tires, etc. It is capable of putting out 130 psi and 2.3cfm which is desirable for filling up the truck tires. Another use I am looking at for it is to blow down my camper water lines for winterization. I would approach this cautiously with several faucets open before turning on the air, just wondering if even with faucets open this might be too great a volume/psi input and it might over pressurize my water system. Thoughts?
2016 EC 960; 2016 RAM 3500 DRW CTD; Superhitch w/42" Ext; 2006 Jeep LJ Rubicon w/16' carhauler
28 REPLIES 28
wa8yxm
Do what I do.. use a pressure regulator between Compressor and RV. I set mine to 50-55 PSI for blow outs. Remove it from the line for inflation of tires.
OldRadios
I made a compressor fitting with an on/off valve. I have a 6 gallon 150 PSI compressor on board and have no problems with adjusting the flow with the shut off valve in the line. I always leave one faucet open and open another before shutting the first.
2006 Fleetwood 26Q
2010 Harley Softail Toad
2015 Ford Focus Toad
Upstate (the other) New York
Boon_Docker
westend wrote:
If you have PEX pipe in the RV and you don't have a cheap filter canister, you should be OK with the little Vlair.
FWIW I have the older air pump system and the fresh water tank is pressurized to push water rather than a pump drawing from the tank. There is a Schrader valve on the fill cap on the exterior. There is also a pressure gauge in this cap. I start my construction grade Hitachi and pressure the tank and system. My pex supply lines are all new, BTW.
I start at the furthest fixture, the bathroom sink, and open that valve. I only have the toilet, shower, and the Kitchen sink after this. Last time, I shuffled back outside to the fill cap and it read 90 psi. That was unexpected but it was a good test for my new plumbing.
You need volume to blow out water lines properly, you have the volume with your system. There is no volume with the compressor the OP is asking about.
westend
'03 F-250 4x4 CC
bid_time
Nomad II
Nomad II
2oldman wrote:
I think I'd prefer a tanked compressor for that job. It's about blowing a lot of air through the lines, not pressurizing them.
I think this is the answer you should pay attention to.
Boon_Docker
I think you would be pretty disappointed with the lack of volume for blowing out water lines.
tvman44
Get a little regulator to put in the line b4 the camper and set it for abt. 40 psi.
Papa Bob
Husky 16K hitch, Tekonsha P3,
Tin_Pusher
I thought I'd try blowing down rather than antifreeze this year. What I learned:
A 3 gal HF pancake compressor ain't really up to the job. Needed to get done BEFORE spring ๐Ÿ™‚
Bigger the tank the better.
Tin Pusher's Guide To Successful RV'ing: "Don't get mad, don't get in a hurry"
2002 1500HD
2002 Wilderness 265H
1997 Seadoo GTI
1952 Wife;)
ksg5000
I have been using an inexpensive 12 volt compressor to winterize my rig for 20+ years - same compressor that I use to inflate my 65 PSI tires (ain't fast but it works fine). Anecdotal evidence that you don't need "bigger" to blow water out of RV water lines.
Kevin
2oldman
RoyB
If that VIAIR model is a tankless type it will takes longer to build up pressure each time you turn it...
My 12VDC Air Compressor is a tankless type and I have plenty of time to turn it on and walk inside my POPUP trailer and open a water spigot...
I have the older MV50 Tankless 12VDC Air Compressor.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
DrewE
The simplest and best solution in my opinion is to get an air pressure regulator for use when winterizing. Harbor Freight (among other many places) sells small ones that would be perfectly sufficient for this use for a few dollars. You don't need anything too precise or consistent for this use.
Always leaving a tap or valve open should prevent any great pressure buildup in the plumbing lines. They theoretically ought to be able to withstand 130 psi, though any slugs of water that are being blown along could produce much higher stresses due to their inertia when they hit constrictions etc.
Trackrig
It should work if you do it very cautiously. The Viair, while it will put out high pressure, is still a low volume air compressor.
Open all of your faucets before turning on the Viair. Then start the compressor, let it run for a moment until water and air are blowing out the faucets. Let it run fur a while.
After about 5 minutes, shut one or two of the faucets. Watch how hard the air is blowing out of the rest of the faucets. You want to judge that the air coming out of the faucets is no more than 45PSI that can hurt the plumbing.
As I think about this more, the Viair being a high pressure but low volume compressor, it might not put out enough air volume to blow out water lines?
Whatever you do, don't shut all of the valves. If all the valves are closed it will develop enough air pressure to rupture things.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
dons2346
I would not want that much pressure in my water lines, especially the water pump. If yo could dial it down to 45 psi, that would be fine.
