โJul-24-2022 03:48 PM
โJul-25-2022 01:14 PM
โJul-25-2022 12:01 PM
โJul-25-2022 11:32 AM
PButler96 wrote:
If they're OEM lighting on a Dometic A&E awning another possibility is they are junk, which they pretty much are even when new. It's not uncommon for a few LEDs to go out, or all of them.
โJul-25-2022 11:31 AM
wanderingaimlessly wrote:
Not trying to be snide, but did you check at the switch for voltage?
At least that will send you either to the lights, or back toward the fuse panel. And if none to the switch, can you run a new hot wire to it?
โJul-25-2022 07:11 AM
โJul-25-2022 12:39 AM
โJul-24-2022 04:58 PM
