2 inverters to a 3 position switch?
Joel_T
I'm planning on being able to plug my trailers 30a power cord into either shore power or generator or inverter. We'll use a 300w invertor most of the time but for brief use of microwave, coffee maker, and ?, a 2000w inverter. So, for the electricians out there, can I tie the 2 invertor outlets into a common outlet and use wired remote switches for each inverter in a 3 position switch, also remote, to isolate them?
(I'm aware of the A/C off, converter off, frig on gas requirements)
Lance 15.5 2285 w/rockers Ram2500 4x4 CC 6.4 hemi 6spd w/3.71
Two 6v Crown 260ah / TM-2030 monitor / SC-2030 controller / Two 160w panels / EMSHW30C surge protector / 2000w inverter / TST507 TPMS
25 REPLIES 25
time2roll
A benefit to powering the branch circuits also prevents powering up the water heater or air conditioner inadvertently. Even the microwave will be dark unless the large inverter is switched on. No one will be fooled by the 300w powering the MW clock as ready to go.
I do have my converter on a separate breaker. Still need to manually put the fridge to propane-only or the 300w will draw a lot to keep the fridge cold.
300w can stay on 24/7 for small item convenience while the 2000w is on just as needed. Very user friendly for the rest of the family.
Joel_T
SoundGuy wrote:
Joel_T wrote:
I'm tripping over dollars probably to save maybe 10a a day. The loss I'd take selling a "new" 300w wouldn't be much different than the added expense to set up the second inverter.
If you're so convinced you want to use both inverters - a 300 watt and a 2000 watt - why not just wire both sets of inputs to the battery, simply plug your trailer's main service cable into the inverter you want to use at the time, just as you would into shore power or your genset, and not bother with a multi position, high current switch at all? :h JMO, but I'd be putting any extra $$$ into beefing up the battery reserve to make better use of the 2K inverter's full potential.
I'm not "so" convinced....just exploring alternatives. I'm lazy too....don't want to go outside to plug and unplug options.
SoundGuy
2012 Silverado 1500 Crew Cab
wa8yxm
Been thinking about this.
you can do it but use a FIVE position switch
Inverter 1/off/Inverter 2/OFF/Other source
Always put an OFF between two active sources.
Joel_T
Joel_T
westend wrote:
A good 2K PSW inverter will draw around 1 amp at idle (unless equipped with an idle circuit to minimize draw). A 300W inverter will consume about 500 milliamps at idle. The difference is so small that you won't notice the difference in draw. Having one inverter obviates the use of switches, transfer switches, and any additional wiring which can also fail.
What 2K PSW inverter draws only 1a. Those I've looked at are closer to 2a.
MrWizard
Moderator
Moderator
A Generator produces AC
You run the A/C when you want to cool the RV
This nomenclature makes it easier for everyone to understand and be less confused when talking about electricity
I can explain it to you.
1997 F53 Bounder 36s
time2roll
My 2000w draws about 1800 milliamps at idle. The 300w draws 160 milliamps. It does make a difference when left on continuous. Especially if solar is marginal.
Besides the OP's 300w is already installed.
Vulcan_Rider
SoundGuy wrote:
when dry camping don't even give a thought to how little those bulbs draw. :B
They draw even less when turned OFF. ๐Ÿ˜‰
When the sun goes to sleep, I'm usually not far behind.
SoundGuy
Vulcan Rider wrote:
Having all LED lights probably helps some too.
More than just "some" ... an LED bulb can typically draw 1/6th the power of a similar incandescent bulb. I've got 16 921 LED bulbs in our short 19' camper and when dry camping don't even give a thought to how little those bulbs draw. :B
Vulcan_Rider
valhalla360 wrote:
Keep life simple, you aren't going to save enough amps to justify a complicated failure prone system.
+1
But some people just like to "tinker" and make things "better".
Sometimes it ends up being self-defeating.
When I said that I simply run the gen. when needed, I forgot to mention that having a 12 V flat screen TV really helps a lot.
I got that model by mistake but am REALLY glad that I did.
I find that in the summer time I have to run the Gen. for AC anyway.
In the "winter" I run it about 2 hours morning and evening and that lets me use the TV pretty much all that I want and the little gas furnace keeps the chill off all night too. Having all LED lights probably helps some too.
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
SoundGuy
Agree completely, and idle draw would seem to be a minor concern if one only turns the inverter on when needed and off when it's not, easy to do since many are are supplied with a remote switch that can be mounted inside the trailer. I too don't see any advantage in a complicated wiring scheme when it's much simpler to just mount a single sine wave inverter near the battery and when dry camping just plug the trailer's main service cable into the inverter output, as I've done (7 pics). Simple, easy to implement, and within the limitations of the inverter you've chosen the trailer behaves just as it would when plugged into shore power.
westend
'03 F-250 4x4 CC
