I have never changed shocks on a vehicle before and saw something odd that maybe some of you with more experience can explain.
The lower, longer bolt for the front shock goes through a curled up leaf spring that looks like this:
Both front lower sides have no washer with the nut. Here is the one I have not removed yet:
The top shorter bolts do have washers with the nut but they are on a bracket, not a spring. Of course, all have the two washers that surround the shock eye.
I'm trying to figure out if there is a reason for no washer, perhaps it creates a locking situation? It was very hard to remove with a 1000ft/lb air wrench after prior soaking with penetrating oil for several days. If it should have a washer there is room for one and I would like to get one on there. I looked at the Ford parts site diagrams but they were not showing washers anywhere, even around the shock eye so it did not help.
thanks very much for any advice,
Fred
2007 Tiffin Allegro 28DA
