โMar-22-2018 05:24 PM
โMar-26-2018 10:48 PM
โMar-26-2018 09:35 PM
BFL13 wrote:
I keep reading here about 6s going for about $90 in the States at Costco or Sam's, so whyinheck would you pay the same for a couple of 24s that are so hard to charge properly and are only 150AH when you can get easy to charge 225AH 6s for the same price?
You said you were nervous about 6s. IMO get them anyway--you will be glad you did.
You will have very limited use of those from the inverter with the two 6s, which you will want to run the normal rig 12v things for the whole gang on a long weekend.
โMar-26-2018 09:19 PM
โMar-26-2018 09:14 PM
โMar-26-2018 09:06 PM
โMar-26-2018 07:18 PM
โMar-26-2018 04:38 PM
โMar-26-2018 03:49 PM
MEXICOWANDERER wrote:
Not 13.8 it's adjustable 10.0 - 15.6 volts.
DO NOT TRUST ANY INSTRUMENT OR METER
VERIFY VERIFY VERIFY
โMar-26-2018 03:42 PM
โMar-26-2018 03:30 PM
โMar-26-2018 02:57 PM
time2roll wrote:lawrosa wrote:Not yet fully charged. Look for less than 1 amp per battery to call full charge.
Understood. 14.4 wins out..
So riddle me this..
I have these 12volters on the sears charger. Charging 10 amp setting @15.4 volts and 4 amps going in. SG is now at 1.250.
Its been 2 hours.
Can I conclude any information from this?
Why wouldnt the PD put in the amps @ 14.4? I know you say about the false voltage so just trying to grasp it.
PD will put in the amps at 14.4, just slower.
You can get a PD-14.8 to be a little faster. Quite frankly I like the IOTA algorithm but it does take time. Fully charging also takes time. Fully charging a battery that has been bouncing up to 90% for a week or three takes more time. Boost charge to 90% is fairly quick as you get into 14.6+ volts.
It is an electro-chemical process. Not the same as filling your gas tank or winding a spring.
โMar-26-2018 01:01 PM
So riddle me this..
Its been 2 hours.
โMar-26-2018 12:47 PM
lawrosa wrote:
Yes adjustable... I would need access to the dial though....And be able to read the meter.. Dont know if I can do it...
http://www.bestconverter.com/Boondocker-BPCM-60-60-Amp-Adjustable-Power-ConverterCharger_p_585.html#...
โMar-26-2018 12:37 PM
