โJun-06-2017 03:00 PM
โJun-07-2017 03:00 PM
OldSmokey wrote:
I'm sure somebody setting about a high current and potentially dangerous project such as this would take time to read advice from professionals ?
the very fact that this post exists is evidence that the poster is seeking education in the art ?
โJun-07-2017 11:52 AM
2oldman wrote:OldSmokey wrote:There is a FAQ, but nobody reads it.
.. perhaps contacting a moderator/admin to set up some sticky posts with information and tutorials about solar,batteries and the like..?
***Link Removed***
โJun-07-2017 11:43 AM
โJun-07-2017 11:41 AM
2oldman wrote:
Good luck being 'flexible' with 4/0 ! ๐
โJun-07-2017 10:54 AM
MrWizard wrote:
A 200 amp shunt and meter, is going to more accurate at average RV power loads than a 500 amp shunt and meter
โJun-07-2017 10:45 AM
โJun-07-2017 10:01 AM
MrWizard wrote:
If you run over 200 amps for several minutes
That might be a problem
A start up spike on the MW would only last seconds at the most and still be under the 200 amps
There is no single item in the RV that can consume that much power
You would need to run wh and MW at the same time
And you don't have enough battery to run the wh from the inverter
And take showers
What do you expect to do that is going to require extended power over 200 amps
I have a 200 amp shunt
And I have baked potatoes in the mw 5~8 minutes, depending on the potatoes
No problems
โJun-07-2017 09:45 AM
โJun-07-2017 09:31 AM
โJun-07-2017 09:24 AM
BFL13 wrote:
Doing 50-90s or 50-80s, a voltmeter cannot tell you when to stop the generator when charging, which is where an ammeter is so useful.
However you can watch the voltage as the PD70 gets the battery voltage up to 14.4 and then just allow some more time for an absorption stage. Time2roll suggests an hour for that, thinking 35 amps on 220AH for a 50-90. With 70 amps on four batts you would have the same time.
A 70 amper on 440AH doing a 50-90 would take about two hours at 70 amps constant to reach 14.4 at 80% (all Bulk stage), then another hour of tapering amps Absorption stage to get from 80 to 90. Total three hours of gen time. You can save an hour of gen time by doing 50-80s instead if you can love with than many AH and you can get the batts fully charged not too long after doing a few of those. It makes for more sulfation to only reach at 80 than to hit 90.
So that only takes a voltmeter and a clock.
EDIT--you can run short wires from the converter over to the inverter and then use the longer fat wires from there to battery. You can still use the 70s second set of terminals for something.
โJun-07-2017 09:22 AM
DiskDoctr wrote:Good luck being 'flexible' with 4/0 ! ๐
..the 4/0 tomorrow for those leads. That will allow me to be a bit flexible on the cable routing..
โJun-07-2017 09:18 AM
2oldman wrote:
works for me...you could use 2 #2 from the inverter.
โJun-07-2017 09:13 AM
โJun-07-2017 09:01 AM
DiskDoctr wrote:works for me...you could use 2 #2 from the inverter.
Also, since it looks like #2 AWG is plenty for the 9270, a substantial savings can be had by using a single #2 wire everywhere except the leads from the battery bank to the inverter.Does that sound correct?
