โJun-15-2021 08:50 AM
โJun-16-2021 08:35 AM
โJun-16-2021 08:15 AM
Lynnmor wrote:
There is no need to apply the 50 lb. ft. unless you just replaced the bearing races. The idea is to make sure the bearings are completely pushed in place. Just a firm tightening with a channel lock pliers, and then back off is all that is needed on subsequent work. The final adjustment is to have the least amount of play possible, but no preload.
Gdetrailer wrote:
Procedure according to Dexter axle service manual HERE
Page 56..
approximately 50 Ft. Lbs.(12" wrench or pliers with full hand force.)
โJun-16-2021 01:19 AM
โJun-15-2021 04:35 PM
โJun-15-2021 04:28 PM
wa8yxm wrote:
For the socket.. If all else fails take a nut to the hardware store and find the socket that fits
And yes I like to use a torque wrench.
โJun-15-2021 03:32 PM
โJun-15-2021 11:23 AM
โJun-15-2021 10:20 AM
