400 amp inductive panel meter
MEXICOWANDERER
Thought this might be https://www.ebay.com/itm/bayite-DC-5-120V-400A-Mini-Digital-Current-Voltage-Amp-Meter-Gauge-with-Hal...of interest...
bayite DC 5-120V 400A Mini Digital Current Voltage Amp Meter Gauge with Hall Effect Pickup
US $26.99
11 REPLIES 11
MEXICOWANDERER
Will these also display discharge current? Other eBay listings claim that they do but there seems to be no provision for a minus symbol
Extra decimal point in front of numbers. .12.8
This thing is not meant to be a portable diagnostic instrument. Hand held instruments have finer resolution and are far more rugged.
MrWizard
Moderator
Moderator
These are DC , battery banks, DIY electric vehicle etc..
And yes there are some different ones for AC, using a CT coil
I have one I built in to a plastic ammo box, with 30 amp RV pigtails
So I can measure shore power or portable generator power
Amps volts PF KwHr VA
I can explain it to you.
1997 F53 Bounder 36s
Housted
I have 2 of them to monitor inverter amps and battery to coach amps
I made extender cables about 15 feet long. Both work great.
Kind of an eye opener about the amps the inverter pulls when she uses her hair dryer or we run the micro wave. We have a 3000 watt inverter.
Housted
2019 Forrest River Forrester 3051S 2014 Honda CRV toad.
1000 W Solar, converted to 50 amp
400 Amps of LiFePO4,3000 Watt Inverter, Refer converted with JC refrigeration unit, Sofa replaced with 2 swivel chairs, over cab bed converted to TV mount and storage
Tom_M1
My clamp on meter does both AC and DC and uses a Hall sensor. I haven't seen a panel meter that does both.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
wa8yxm
I would not mind a couple of big hall effect. Do they work on AC and DC or Just one or the other???
I'd love to monitor all current on the big battery banks. but. alas shunts cost and are harder to install
Danger of a short with that bakelite ring.. ZERO.
Tom_M1
MrWizard wrote:
its just a re-used picture, from one of the earlier smaller amp versions
i have several of the 100amp version
monitor charge to the batteries and inverter load
Will these also display discharge current? Other eBay listings claim that they do but there seems to be no provision for a minus symbol.
One thing to note is that the 400 amp version has a resolution of 1 amp. The 100 amp version has a resolution of .3 amp.
Tom
2005 Born Free 24RB
Minneapolis, MN
MEXICOWANDERER
It's faster to install than a shunt and less exposed to shorts and longs.
Heck I may even order one for the toad. It would have screamed PROBLEM! when the starter motor slowly was dying. I need a titanic capacitor to smuuuuuuuuuth out the hungarian movie actress MoPar ECU voltage regulator readings.
MrWizard
Moderator
Moderator
LScamper
400 Amp flash bulb? No problem it is only 198 Amp!
Lou
wa8yxm
I don't know but that wire they show for the current carrying wire. at 400 amps that puppy is a flash bulb.
