โJun-22-2015 07:20 AM
โJun-23-2015 06:24 AM
โJun-22-2015 08:30 PM
โJun-22-2015 05:54 PM
Lazydude wrote:Good point. Best to turn off ALL breakers except the main and AC branch circuit to eliminate all other items.
Depending on the battery charge your converter will draw up to 900 watts,so shut off the breaker for the converter and try the A/C again.
โJun-22-2015 05:45 PM
โJun-22-2015 01:39 PM
โJun-22-2015 12:50 PM
โJun-22-2015 08:38 AM
BB_TX wrote:
15 amp is marginal for running an AC. It is possible your friend's outlet was actually a 20 amp circuit. Possible your outlet is on a breaker that is also connected to other outlets that have other loads on it. A breaker typically is wired to more than a single outlet.
โJun-22-2015 08:30 AM
โJun-22-2015 07:49 AM
โJun-22-2015 07:45 AM
โJun-22-2015 07:32 AM
โJun-22-2015 07:30 AM
