5th Wheel Landing Gear
Camper117
While camping this weekend, I mentioned to a fellow camper that my landing gear was out of sync (one foot hitting the ground before the other). He said if I were to raise the landing gear all the way up, the feet would realign and hit the ground at the same time, provided the ground was level.
I decided to try that when I got home today. So, I raised the landing gear up all the way. When it reached the upper limit, the motor stopped and hasn't worked since. So I used the manual crank and got unhooked. I have a hard time the swithc picked that exact moment ot go out.
Does anybody have any ideas? Thanks
15 REPLIES 15
raroberts
That person gave you some very bad advice. What you did when you hit the top was probably blowing the fuse for the motor. They do not even out when you go to the top. I'm not talking about hydraulic jacksonly the gear driven Jacks
08 F450 4X4 Lariat
07 Stellar 37' 5W Toyhauler
95 XR600R
03 XR400
07 660 Rhino
75 Z1B
