6v vs 12v battery question
Cdash
I have two battery questions that I can't find answers to. I'm hoping that the questions are not too stupid.
1. Amp-hour ratings - when I look at battery specs, I see different amp-hour ratings for different periods of time for the same battery, but when people talk about batteries, they only mention amp-hours. What time period from the battery spec charts is commonky used?
2. For 6v batteries, I understand that I'd need two hooked in series to make it 12v. If I'm am looking at a single 6V battery that is 100 amp-hours (made up number) when I hook up two of them in series to make a 12V system, do I have 100 amp-hours at 12v, or would I have 200 amp-hours? Wasn't sure if amperage gets cut in half because voltage doubles....
Thanks for the help!
23 REPLIES 23
korbe
2oldman wrote:
"(made up number)"
Yes, but he could have at least made up a credible one. My goodness....
2oldman
"(made up number)"
Bobbo
Almot wrote:
I don't see much reason for getting 2*6V @100 AH each. Unless you have a really small trailer or van, or lifting 62-63 lbs is difficult to you. Most 2*6V setups are 220-230 AH per battery. 63 lbs is a lot of weight to lift, I have to say.
It was a made up number to ask his question.
Bobbo and Lin
RJsfishin
He din't say he was getting 6'ers at 100 amps, I doubt there is such a thing.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
Almot
Cdash
Dennis M M wrote:
Lots of good info here The 12 Volt Side of Life
I agree, good information! Believe it or not, I did read that first thinking that it would be in there, but it isn't. Figured that I needed the "12 volt side of life for dummies" version.
2oldman
Series= add voltage, same amps. Parallel = add amps, same voltage.
Dennis_M_M
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
Ed_Gee
The standard most used for RV is the amp hour rating over 20 hours.... the time it takes to draw the fully charged battery down to 10.5V (empty) at a constant current of 5 amps.
Yes, two 6 Volt 100AH batteries in series will give you 12 Volts at 100 AH.
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
