โOct-15-2013 02:54 PM
โOct-29-2013 04:15 PM
MEXICOWANDERER wrote:
The old cabin is closer to '53 than '93
My body is 7 years older than your "old" cabin. Pffftttttt!
โOct-29-2013 03:25 PM
โOct-29-2013 02:45 PM
โOct-29-2013 02:32 PM
โOct-29-2013 07:48 AM
โOct-29-2013 06:47 AM
โOct-29-2013 05:53 AM
BFL13 wrote:EldIr wrote:BFL13 wrote:
No way is that 3 amps with a 300w inverter. Something else must be going on there.
Eg using the 1000w inverter and a 120v CFL lamp I get a 2 amp draw showing on the Trimetric, vs a 3 amp draw with no inverter and one 12v two bulb lamp. The CFL lights up the whole place in comparison with the 12v lamp. ( I don't have the newer, better LEDs for the 12v lamps)
I won't be back to the cabin until the week after next due to work. I'll recheck the inverter manual and test the draw with my Fluke but I'd swear the manual said the inverter draws about 30w. It does have a cooling fan that runs any time it's on regardless of load and I know some of those aren't very efficient. It is quite old from before pure-sine inverters became all the rage. (back then, even the cheap modified-sine were still expensive not like the 30 dollar ones at the auto parts stores now.)
Back in the 90s ๐ they had 12v TVs etc so you didn't need an inverter and RVers got the idea that it was easier on the batteries to use 12v directly instead of wall warts on 120.
Now that is all "so yesterday" with switch mode mofset inverters and LED Tvs, CFL or LED lights. etc etc. Today you can do it all via inverter and get better TVs and other things to run off 120v and forget the whole 12v idea unless forced to.
New cabin in 2013? Do a 20yr upgrade from the old '93 cabin ๐
โOct-28-2013 10:00 PM
EldIr wrote:Thanks for the update! Let us know what you end up doing.
Having read all your replies, we will definitely look for a more efficient inverter for the new cabin and will most likely do away with all 12v stuff except maybe still a car stereo.
I should note that there also is a full surround-sound home theater setup with subwoofer for when the gen is running :C
โOct-28-2013 10:43 AM
EldIr wrote:
The inverter at our cabin is an AIMS PWRI30012S. These are the specs:
No load power consumption - under 20w +/- 2w.
โOct-28-2013 10:31 AM
mena661 wrote:
30W standby is WAY too much. Mine draws .26A and it's a 300W PSW.
โOct-17-2013 09:16 PM
EldIr wrote:Car stereo is a great idea as home entertainment systems generally draw a lot of power. Although searching for the right components will find really low draw electronics. I found a Bluray player, while I was searching for something the 12V guys can use, that only draws 10W per it's specs but it's 120V only (not good for the 12v guys...found them something that draws ~14W).
We have cfl's and an lcd tv to run off the inverter, but we're still programmed to run the inverter as little as possible to save the batteries. That's why the car stereo and running the cell phone booster off 12v. I'll update the inverter draw as soon as I get back up there.
โOct-17-2013 07:52 PM
โOct-17-2013 05:59 PM
โOct-17-2013 04:24 PM
